Rank the volunteer roles by Contact Rate
I would say that in general, Referees would probably end up with 5 contacts meeting the CDC definition for “Close”, those 5 being the other referees. There’s certainly a risk that they end up with more (Official Scorers being the primary use case, if they’re used, with the gate-operating Field Reset crew members being the secondary). I think with some mitigation you can lock that at 5 close contacts. There’s just one problem with that micro-bubble: The Head Referee.
See, the Head Referee starts the day with the VC, LRI, JA, FTA (and possibly FTAAs), FS, RD(s), Event Manager, and a few other people in a meeting. Assume that each and every person in that meeting is a close contact of everybody else in the meeting, because it happens every day and often goes over 15 minutes, in a private area off to the side of the event. So there’s a bubble of at LEAST 8 people, all of whom are critical to the event, all of whom often do multiple events, any one of whom could get the disease.
Referee: 4 contacts that are probably clean, 1 at high risk.
Head Referee: 4 probably clean contacts, 8 contacts at varying risks from low (VC) to high (LRI and FTA). And that’s JUST the volunteers: Assume 8 more contacts at unknown risk (Alliance Captains), and probably about 5-10 close contacts that may or may not overlap with the AC group due to use of the Question Box.
Incidentally… I’ll bet some of you saw that meeting note I made earlier, and are now thinking “uh-oh”.
For those that aren't...
Hypothetical scenario: Little Johnny on FRC666 catches an asymptomatic case from an unknown source, and it isn’t detected before he attends the Magnolia Regional. Johnny helps get the robot through inspection, and due to a particularly annoying rules issue Inspector Jim brings in LRI Bob to help out, both being close contacts of Johnny due to the time working on the issue. Note that LRI Bob and most of the KVs are scheduled for events for the next two weeks.
LRI Bob goes to the KV meeting the next morning. At this point, nobody knows that Johnny had our contagious little friend. LRI Bob also goes the morning after that. Nothing’s showed up yet. The KVs interact with their teams of volunteers.
A couple days after the event, Johnny gets tested for some reason and it comes back positive. A contact trace is activated. Jim and Bob get tested. Positive. The KVs are alerted. They go to get tested. At least half show positive. Let’s say it’s the FTAA, the CSA, the LRI, the Head Ref, and the Field Supervisor.
This, my friends, is the nightmare scenario. If you haven’t nearly freaked out, you should be. Remember I said that most of the KVs are probably doing another event shortly? Not any more! And a smart KV who didn’t test positive will still hole up for a couple weeks (in case the test timing was off). At this point, your best assumption is that every single team had an interaction with someone who is somewhere in the chain of positives, and probably about half the volunteers did too.
Unless you’re in Texas or Florida, that’s it for events for at least the next two weeks and probably the rest of the season. Nobody’s going to be silly enough to allow one. Even if enough people and teams are functional to play one. Even Texas might take note and do a shutdown. All because one person’s contact chain led right through the KV meeting.
That meeting has Nate’s 1, 3, 4, 7, and 8, possibly 6, 11, and 10. Maybe a few others (15 comes to mind). That’s 8 close contacts immediately for everybody at the meeting.
Of course, there’s a few easy mitigations: Meeting gets held outdoors (outside the venue) or on the field, or not at all (HAH!), or via a Zoom. That should take the contacts from it to near-zero, allowing the KVs to worry about their normal interactions. Ditto for the AC meeting (held on the field), the spread-out-and-holler situation should work for that just fine.
Final score for the Head Ref: 5 low-risk, and with proper mitigation in the required meetings, and some creativity around the Question Box(es), I think you could get down to another 5 medium-to-high risk.
HR (and often times, the refs), FTA and LRI have a long contact with all the drive teams in the “coaches” meeting.
Some very good thinking in this thread so far. Do you think FIRST is doing this analysis and looking for mitigations? Why or why not?
Who knows… they haven’t communicated anything along those lines! The best thing FIRST can do is maximize communication. I would love to hear their current plans, their contingency plans, and their contingency plans for their contingency plans.
Everybody and their grandmother understands that things can change dramatically from month to month. We won’t harbor hard feelings if FIRST changes their policies as the conditions of the pandemic change.
I don’t think it’s too much to expect regular communication from HQ at this point. Teams are going to be asked by their stakeholders as to how things are going to go this year… it would be great to have something to tell them.
Yes. Simply put, I’ve had discussions like this with individuals that have direct input into these sorts of plans. I would expect every key volunteer to be talking with their local VC’s (who would then communicate it up the chain to HQ) or with their area’s chief (Like Big Al/Chuck for LRI’s).
I can also say that a year or so ago, when we didn’t know if the 2021 season was going to happen or not, I provided direct input into what it would look like to do inspections at least partially virtual - which steps we could do virtual, which ones we would really still want to be in person. So it’s something that’s been considered, but obviously not used yet.
I think it’s fine (right now) for FIRST not to have announced any plans. Team registration isn’t open yet, volunteer registration isn’t open yet. When announcing something like covid plans, you run the risk of things changing. Sure, we all know that and are fine with it… but when you change published plans, especially for something on the scale of FRC, you run into a problem of people looking at the wrong version. I can’t tell you the number of times LRI’s or HR’s have had to deal with teams bringing up kick-off rules that have since changed or been clarified by the time we get to the event. This would be no different - if covid rules were announced in June, before the delta surge started, those rules would look a lot different than they do now. This isn’t something we should be rushing to get rules out on. Give them to us a week or two before registration, and I’ll be happy enough. It’ll be plenty of time for me to compare their plans to my school’s plans, bring any concerns to the administration, and figure out a plan for registration.
Basically every off-season event has been conducted using an honor system for robot inspection. There’s the caveat that the majority of robots passed inspection sometime during the official season, but I think anyone who’s been to enough off-season events has witnessed a post-season modification or practice bot that wouldn’t have passed inspection.
While a zero cheat utopia would be nice, I think we all know now that even under more stringent inspection requirements there are still honor code rules and instances of “creative interpretations” of rules. We have nothing beyond a student and mentor signature that enforces that teams didn’t violate pre-season work rules or modify their motors.
In my experience inspection is not so much to catch cheating or creative interpretations. It’s more to check that teams actually paid attention to build rules. Because there’s always someone that comes in grossly oversize, overweight, incorrect wiring or pneumatics, etc. They’re not trying to get away with it, they just didn’t pay attention.
Plus, a good inspector/LRI will help struggling teams to get out to the field for as many of their matches as possible.
QFT. The times I’ve managed to see teams that didn’t get the build rules at their first few matches, it often became clear that their understanding of the game rules is based on little or nothing more than the reveal video.
Here’s a suggestion, not to replace inspection by a volunteer, but to promote useful in-team inspection to simplify the real one: Make the RI test (or at least AN RI test) available on-line for teams, and encourage teams to take it (perhaps one mentor and one student per team). Make it clear that doing a conscientious self-inspection will not only reduce contact time with volunteers, but reduce time at the event needed for remediation, leaving more time for the practice field. It won’t help the ones who don’t pay attention, but it can help those in the middle greatly.
The inspection checklist is public.
That’s what I was alluding to with the sanity check. I’m not really sure what the procedure would be otherwise for an obviously out of spec robot with no way to prevent it from taking the field. I guess a ref could call it out, but that could unnecessarily screw teams over if there’s no practice matches.
That’s not the same thing. Passing a test at least means reading the rules well enough to absorb at least some of it. Answering a question (or better yet explaining something to someone else) is reinforcement and results in better retention than just reading something.
Especially with some photos to reinforce certain in-spec vs out-of-spec situations?
With inadvertant risk of communication that something Is The One True Way, of course.
That test is open book for inspectors although realistically if you can’t pass it closed book you shouldn’t be an inspector
The off season event in San Antonio did remote inspections. They sent out the list, photos of common issues and things to.look at. You filled out the checklist and sent in specific photos. The organizers reviewed and sent feedback.
Worked nicely!
Note that the point of immunization is to move people from “S” to “R”, without having to actually be “I” (Susceptible / Infectious / Recovered). This is still, by far, the most efficacious intervention we have. Getting the R fraction high enough is how epidemics end. We really should be there by this coming season – what happens this winter should make this clear, one way or another.
