Ranking Points
My understanding from reading the rues is there are 2 things that give you points towards ranking.
  1. Breaching the defenses.
  2. Capturing the tower.
Any thoughts?
3, actually. Win the match (or tie).
so are these being used as the to determine Qual ranking, or is it still on points?
Read section [strike]5.4.3[/strike]5.3.4.
The playoff match bracket does not explain anything. Am i misreading something?
5.3.3 Does state that they are used, but in what way will points (NOT RP) be used in qualification matches? are they useless then?
They determine win/loss/tie, which is worth half the possible ranking points.
My apologies for my (too) quick fingers. Check 5.3.4.
Does anyone know if it is illegal to travel over a defensive wall thing more than 2 times?
I have not found a rule against it. Have you?
P.S. so that someone with the same question can find it later, please call defenses by the official term.
again, do you mean 5.3.3? that just says that teams are seeded from 1 to N, N being the number of teams. This also does not explain the use of points in Qual’s if RP is used
5.3.4 also states the sorting criteria for ranking. The first being Ranking Score. 5.3.3 states that Ranking Points make up the Ranking Score.
The use of points (earned by scoring boulders in goals and by crossing defenses) in the qualification rounds is to determine win, lose, or tie.
Points are used to WIN a match. Win = 2 RP, tie = 1. More points than your opponent = 1 win.
Points or Ranking Points?
These similar names are getting confusing…
So RP would be used to Determine W/L/T and Points would be used to Determine Qual Seeding?
Wrong way around. Points, scored by the various actions on the field, determine W/L/T. W/L/T plus the “bonus” actions (Breach and Capture) give RP, which give a Rank (seed) for the competition.
Points in a match are used to determine the W/L/T which in turn decide Ranking Points (along with Breach and Capture).
Ranking Points are used to determine ranking as detailed in 5.3.3 and 5.3.4.
You need to read the entire manual and use the information together to understand the game. It is hard to understand things with only bits and pieces of knowledge.
Trust me, i have read the manual. This is just fairly confusing to me and i cant seem to understand it, hence why i am here. I also may not be the only one, and its good to have an ELI5 understanding of something important.
So points Determine W/L/T, and then RP determines seed? then in the playoffs RP is not used and Just Points are used?
During Playoffs, each round is decided by the first alliance to get two wins.
i misread that, my bad.
Can i please get an ELI5 of what Points and Ranking Points decide?
If you score the most points in a match, you win the match. Then you are given 2 ranking points for the win. (Or 1 ranking point for a tie.)
You also get additional ranking points for the BREACH and CAPTURE.
That means you can earn up to 4 RP’s per match.
Once all the matches are complete, the team with the most RP’s is ranked #1 for alliance selection. The next highest total is #2, etc. There are tiebreaker rules to determine the order of teams with the same number of ranking points.
Once you hit the playoffs, there are no more ranking points.
Thank you SO MUCH. This explains everything really well for me.
