Does anyone out there use the new Raptor Track chassis?
We are really happy with it, but, we are experiencing some chain rubbing issues. We have double checked the installation instructions, and we believe we have it put together correctly. Is there anything we can do to fix this?
The chain is running on the bearing? If you are sure the bearing doesn’t need to be flipped, you could add a spacer to hex shaft to give you that extra clearance.
From the assembly instructions, it appears that the bearing on the shaft should be pressed in the same direction as the on it’s rubbing on (Step 3 on page 5), and there should be a 3/16" spacer between the hub and the bearing (step 8 on page 6). I can’t tell from the picture if it’s set up that way, but I’m guessing the spacer isn’t in there.
Yeah, that’s what I’m planning on doing. I just wanted to see if there was anything obvious that I was missing, or if AndyMark came out with any updates!
