I’m using the FRC image running on a Raspberry Pi 4 to do vision detection for the game. My vision code is running correctly, and at the end it puts some values on SmartDashboard. My issue is that sometimes when I connect the Pi to the robot it doesn’t connect to the NetworkTables/SmartDashboard. Also, most of the time I can view the web dashboard and my camera streams but sometimes that fails as well. If I run the Pi just connected to my computer as a server, than the NetworkTables and web dashboard works perfectly all the time. Our robot is coded in Java, the Pi is in Python, and both the roboRIO and the Pi have a static IP.
What is your network setup? E.g. how are the Pi, computer, and RoboRIO interconnected?
The Pi is connected via Ethernet to the radio, and powered through a USB slot on the RIO. We connect to the robot with WiFi, and then we just view the web dashboard with the static IP of the pi.
Sometimes there are communication issues between the two ports of the radio. Try putting an Ethernet switch on the robot and connecting the radio, Rio, and Pi to it.
