There were many posts that were very useful regarding how to wire up the encoders (I believe, they were Andy Mark). But before we get into the fun stuff of splicing the wires, our adviser insists that we figure out how to read its output values, so Programming can do their job. Would anyone happen to know how we can test this?
Encoder *e = new Encoder(1, 2); //1 & 2 = your dig io pins for channel a & b
e->Start();
int distance = e->GetDistance();
// use distance for whatever you want
The output values are easy to read. But they can be done only once you splice up the wires. I suggest you probe it on to a Oscilloscope and look at the quadrature signals. As you ramp up the motor, the signals should come closer to each other. If there’s not a ton of noise, and if it looks “alright” then you should splice it. I wish they gave us two PWM outs instead of 1 4-lane cable.
Once you splice it and connect the correct A & B ports, then it’s really simple, just go to WPI Libraries -> Sensors -> Encoders and do the usual thing with Open, Get, Close. Though, this time, you may want to fiddle around with the Configuring the Timers.
It’s pretty easy in labview. There’s an encoder vi in the library. Just tell it what digital IO pins you’ve connected it to and that’s all there is to it.
By “isolated the bug” he means that it discovered the source. As indicated in the first thread that he linked to the bug is going to be addressed in the next software update.
It’s supposed to come out sometime tomorrow (Monday) and the encoder problem is fixed. If you were just reading distance or the count, that has always worked. The problem was just with reading the period or rate.
