Recommended connectors for voltage regulator module
Hi I recall seeing somewhere someone using connectors for insertion into e.g. the voltage regulator module, these were pins with serrations of sorts, so that the internal spring clip would grab the connector more effectively. Can anyone advise? Thanksl
Do you mean the Weidmuller ferrules listed here?
http://www.ctr-electronics.com/cabling.html?limit=all
This should give you the basic idea:
Thanks Ernst, those appear to be the ones and now I know the term ferrule.
Can I also say that Inventables offers a set of these ferrules https://www.inventables.com/technologies/insulated-ferrule-kit which you could use your $100 voucher in the kit of parts this year to purchase as well as the crimping tool https://www.inventables.com/technologies/ferrule-crimper
