Red light
Our distribution panel has a red light in a jaguar there’s no electricic current, what do we have to do?
we’ve already changed the fuse, the cable position:confused:
Did you try a different spot on the PDB? Try a different Jaguar?
The red light indicates that there is no breaker installed. I’m assuming that the fuse you referred to was a breaker you tried to put in, and it didn’t fix the problem. The only possibilities I can think of are a broken breaker or a broken slot on the PDB. Try another breaker, and if that doesn’t work, you will probably need to leave that slot empty (or replace your PDB).
The light could also be indicating that the breaker is tripped because of a short circuit on that power branch. If that were the case, it would most likely be blinking off briefly as the breaker tries to reset every so often, accompanied by a clicking sound, and the breaker would probably be warm to the touch.
RHP it is also possible that you have wiring issue between the PD and the Jaguar.
Just to be sure, the PD has a breaker installed for that Jaguar. The red LED is the one on the side of the PD under the WAGO connector block. The Jaguar it feeds shows a normal LED indication when the robot is turned on and when it is enabled.
Or
Is the LED on the Jaguar and the Jaguar has no output.
