Reimaging the cRIO - Help!
Wow! We changed nothing and at startup today it now recognizes the current image which is new. Still no movement/response to joysticks. So I would still love feedback… :slight_smile:
These images are the error messages in driver station and our cRIO imaging tool…
Here are the error messages via the driver station… Warning
The driver station LEDs to the left of the messages show that the laptop is able to ping the robot. Further to the left are Communications and Code LEDs, what are the state of those?
The warnings shown in the window are lower level details. If they aren’t errors, you don’t really need to worry about them.
Greg McKaskle
At first glance the cRIO image seems to be fine. It’s operating and talking back to the Driver station. I’ve attached three screenshots of the Driver Station app tabs for Operation, Diagnostics, and Setup, so you can compare them with your own. You can see that the warning/info messages on the second image of the Diagnostics tab are similar to your photo. These have the Driver station PC connected directly to the cRIO, so no bridge.
In additional to answering Greg’s question, about the status shown on the left of all three screenshots (communications/Robot Code/Joysticks and Teleoperated Enabled),
A couple of things to check:
Thanks so much for the help. Our river station appears to match yours’ and the communication, joystick and robot code lights are all green. However, it’s never turned blue. We are using default code. We downloaded it via the project explorer window… :slight_smile:
If the joystick entry won’t turn blue when you push a button, that means no commands will be sent to the robot.
Try hitting the F1 key to see if the button presses get recognized after that. That forces the Driver Station to check the USB joysticks again.
What kind of joystick are you using?
Would you take a snapshot of the Setup tab for us?
P.S.
Laptop USB is notorious for cutting power to USB ports while the laptop is on battery.[ol]
[li]Make sure your laptop battery is fully charged and preferably plugged in.[/li][li]Check your power saver settings to avoid power cutbacks when the battery is low.[ul][/li][li]Open the Device Manager. Win 8, hold the Windows key and press the ‘x’ key to open a menu in the lower-left and select “Device Manager.” Using Win 7, open the Start Menu, type “Device Manager” in the search field, and click it.[/li][li]Expand “Universal Serial Bus controllers”[/li][li]Right-click each entry titled “USB Root Hub” and select “Properties”[/li][li]Change to the “Power Management” tab[/li][li]Uncheck the check box next to “Allow the computer to turn off this device to save power”[/li][li]Press “OK”[/li][li]Repeat this for each “USB Root Hub” entry[/li][li]Reboot the computer[/ul] [/li][li]If using more than one USB device, i.e., multiple joysticks, distribute the USB load across all the laptop USB ports that you have. Keep critical joysticks on their own USB port.[/li][li]Avoid ganging multiple USB devices up on a single USB hub. Bigger hubs are worse. If used, small hubs are best.[/li][*]Avoid fancy joysticks that draw an excess of USB power. Power hungry fancy sticks or ones with glittery LEDs won’t fare as well as plain vanilla generic joysticks.[/ol]
Here is the image of our setup…
We’re currently attempting to find the original default code to download, just in case we changed something by accident.
As far as the joysticks, this is probably a stupid question, but other than battery usage, does the model matter?
Meaning, do we have to select it somewhere within the code? We used V-Max 2013 flight joysticks for ps3/PC, nothing fancy, just generic joysticks…
From your screen, it seems that you have joysticks, code, and communication to your robot. It is disabled, and it isn’t possible to know how the code was programmed.
My suggestion would be to enable the robot in teleop mode and carefully test it. Perhaps you should put the robot on blocks as you test. You should also be ready to disable or estop it by hitting the spacebar on the driver station if you need to.
Another approach is to go to the dashboard and put the robot into test mode. This lets you read sensors and it lets you enable and test outputs just one at a time.
Greg McKaskle
If you reimaged the cRIO, any user code was erased from it in the process. You must load your code onto the robot again before it will do anything.
Update…
We have code on the robot (downloaded default to cRIO via project explorer and right clicking run on robot main), and the driver station shows that it has code.
We have observed the joystick names going blue when we click buttons but not moving the joystick (changing the axis position).
We have observed the axis values changing as we move the joysticks in the test phase.
We still have not gotten motors to respond to joystick movement…
:slight_smile: thanks for any advice!
…and you Enabled the Driver Station?
Sounds like the cRIO and code are doing fine.
How about the electrical side of things?
Lets discuss the wiring.
cRIO modules seem to be in the correct places.
  • Do you have power wired separately to the Digital Sidecar from the Power Distribution Panel (PDP)?
  • Are all three power LEDs on the Digital Sidecar bright green?
  • Do you have PWM outputs 1 & 2 wired to speed controllers?
  • What are the status lights on the speed controllers doing?
    *]Are the speed controllers separately wired for 12v from the PDP?
Yes to everything now. We originally did not have the digital sidecar wired but do now. It doesn’t see to have changed anything… :frowning: our talons are LEDs are blinking fast. One is blinking orange and one is alternating orange/red. We’ve attempted to recall rated but it didn’t respond. If the robot is not responding to joysticks (although we can see the cRIO. recognizes them via test mode) - can it still calibrate?
More ideas please!! :slight_smile:
The Talon and other speed controllers must receive PWM signals in order for calibration to work as intended.
The orange blink means that the controller isn’t receiving a PWM signal.
Can you enable the robot? When it is enabled, if the Talons continue to blink orange, it means an electrical wiring problem or wiring that doesn’t match code is the most likely issue.
Again, I’d probably enable the robot in test mode, scroll down the test tab and review the channel numbers for each motor. Run the motors individually as you verify that PWM wiring matches what was opened in the code. If most of the PWMs do not work or work unreliably, you may want to verify that the cable between the digital module and digital breakout board is properly seated and working properly. There were cables in the kit last year I believe that had a reversed connector. Also verify that the blue breakout has its own power connected and its LEDs are bright. The PWM current is sufficient to drive a few motors, but cannot supply more than three at the same time.
Greg McKaskle
We definitely have lights on the digital sidecar at this point.
We can enable the robot but how do we run motors? Is it a function of the test view? And if so, do we need to make separate portions of code?
[/li]
There is a PDP on board? There’s your problem :smiley:
On a more serious note, Mark meant the PDB, Power Distribution Board
Page three of this tutorial – https://decibel.ni.com/content/docs/DOC-26314 – may help out.
The short answer is that if you open a resource in your code and register it by name, it will show up. If you select an actuator value in the table, a control will display allowing you to modify the value. Motors are somewhat dangerous, so they utilize a momentary enable button. This means, you select, then set the desired speed, then click and hold the enable button for as long as you want the motor controller to be sent that value. Other actuators don’t require the enable button.
If this doesn’t work, please describe what it does do to the LEDs, etc. And don’t forget to enable the robot on the driver station.
Greg McKaskle
Okay, still no movement from the joysticks… :frowning:
We’re starting to worry that we’ve missed something really basic. We’ve been reading/watching various tutorials but haven’t stumbled across any solutions yet.
Following everything we’re reading about the test function and no response.
  • Are we correct that we can pull up default code, input our IP address, change jaguars to talons and download? Or is there something else critical that needs to happen?
  • All updates are installed on the computer
  • The cRIO is now imaged
  • The talons are still fast blinking orange on one and red/orange alternating fast blinks on the other. We attempted to calibrate and didn’t observe any change (it didn’t give the red error or green success, just kept with the fast blinking).
  • The test mode lets us see that it is measuring joystick movement, just the robot doesn’t respond…
Again, thanks so much for any advice and input!
Greetings,
We ran into this same problem last night. Try flipping your PWM’s in your controller. Your issues may not be in code, but physical. If the PWMs are in backward you will be the symptoms you are describing
That suggests a power or wiring problem. Alternating red and orange is not normal behavior for a Talon.
Can you tell us exactly what is connected to your Digital Sidecar, and where each wire from it goes? Photographs of your wiring would be useful, including the LEDs if possible.
