Relay for Pump q?
What relay do u hook th pump up to so that it goes on and off buy itself, or does it not matter thanks?
You have to insert code into the program to make the pump turn on and off. Then you hook the pump to whatever relay used in the code. Check the White Papers section, I think the code is there.
Re: Connecting the pump - check out this thread
http://www.chiefdelphi.com/forums/showthread.php?s=&threadid=1658&highlight=pump
Doug Hogg
