ok, we have our pneumatic cylinder in our robot using the standard FESTO valve set up as a two stage device. When the piston is out it latches a rod that is pulled back by surgical tubing. What I’m wondering is how we would release this cylinder at the end of the match because if we leave it out we have a lot of stored up energy but theres no way to retract the cylinder after the match ends because it is wired up as a two stage cylinder without an automatic return when power is removed. We have come up with 2 ideas for this to work.
- have it finish the match with piston out and energy stored up and have a “lock” make sure our kicker doesn’t fire.
- have a small circuit that when power is removed it uses stored up energy in a capacitor to fire the other side to release it.
in my opinion BOTH methods are not valid because in option 1 we have a lot of energy stored in the bot at the end and if i am correct all this energy needs to be released at end of match. and option 2 seems illegal as well because we are triggering electrical components to move AFTER the robot is disabled. Idea 2 may not be “illegal” but in my opinion judges would see this as a MAJOR safety hazard on the bot.
Long and short of it…i need to get an official ruling on this or have any other ideas suggested on this topic. Thank You.
