Today at the Greater Toronto Central Regional, the Field Stewards elected to remove the fabric and lower pipe from the Low Bar defense, keeping the upper frame of it on the field. They seemed to remove it after all of the flaps became too damaged for match play.
Not that surprising if you think about it. With the allowed extensions, the leading edge of the robot is not necessarily the bumper It will be interesting to see what First decides to do about this. Requiring more scrutiny of robot sharp edges is one possibility. Changing the Aluminum pipe out with a lead pipe is another. (admittedly not likely.)
This is proving to be a hard game to the field elements.
They said it would be a penalty if the teams strategically tried to roll a boulder under the low bar from the HP station. If it was not intentional, play will continue.
May have been at kickoff, but now a 15" x 30 chunk of polycarb flipping up and over into a robot would be a very unpleasant change. I can see where teams anticipated a 6 oz pipe going across the top of there robot, but not the polycarb. If the polycarb gets jammed into the robot that can be a bad thing.
Not sure what the fix is, but polycarb sheet isn’t it.
Maybe flaps/ vertical strips of plastic like you see on commercial freezer doors to allow entrance and egress, That would let the robot pass but stop the boulders. The strips would stay attached. They would need to run tests on entanglement.
We used a flap of foam board as a low bar cover in our testing and it survived, but probably wouldn’t last an entire competition.
Personally, I’d like to see a beaded curtain so robots can recreate the Britney Spears Oops!.. I Did it Again artwork, but I would settle for plastic strips. ����
I have been watching the event for the majority of the day, and I’ve seen, on several instances, boulders and the low bar interact in such a way that provides concerning circumstances.
Robots driving onto boulders, under the low bar. It can cause a bit of a jam, as well as damage to the robot if they are going to fast.
Boulders rolling through. The human player station aligns with the low bar, and with a normal toss, the ball can easily get onto the outerworks, or even past it.
I’m curious to see how they deal with this, as not only does this raise scores by, in some occasions, having easier access to boulders, it also makes penalties in regards to boulders going over quite questionable.
We built sidewalls on our robot, depending on the pipe, speed of transit, and the nap of the fabric to keep the flap out of our internals. Beads or strips would behave MUCH differently. We’d probably survive with the plastic strips, but our canopy design would have been much different with beads or strips than with the single flap. I have seen plenty of robot photos posted with similar flap/portcullis deflectors.
Seems like a team update could extend G40 to include “ROBOTS and HUMAN PLAYERS.” I agree, though, that the removal of the flap was an overstep. There’s no way a little bit of duct tape couldn’t have fixed it while they tried to find some more fabric to replace it.
