[Repost] Pathfinder Problem: Robot does not crash but robot code never becomes green
I accidentally posted in the control section. This is a repost from there.
public class DriveAlongProfile extends Command implements RobotMap {
	private Waypoint] _points;
	private Trajectory _leftTrajectory, _rightTrajectory;
	private EncoderFollower _leftEncoderFollower, _rightEncoderFollower;
	private static final Trajectory.FitMethod _FIT_METHOD = Trajectory.FitMethod.HERMITE_CUBIC;
	private static final int _SAMPLES = Trajectory.Config.SAMPLES_HIGH;
	private static final double
		_TIMESTEP = 0.05, //In seconds
		_MAX_VELOCITY = DRIVETRAIN.MAX_VELOCITY_TICKS * CONVERSIONS.TICKS2METERS,
		_MAX_ACCELERATION = DRIVETRAIN.MAX_ACCELERATION_TICKS * CONVERSIONS.TICKS2METERS,
		_MAX_JERK = DRIVETRAIN.MAX_JERK_TICKS * CONVERSIONS.TICKS2METERS;
	private static final double _VELOCITY_RATIO = 1 / _MAX_VELOCITY;
		_drivekP = 1.0,
		_drivekI = 0.01,
		_drivekD = 10.0,
		_drivekA = 0; //Acceleration gain. Tweak this if you want to go to accelerate faster.
	private PIDController _angleController;
	private PIDOut _buffer;
	private PIDIn _pidSource;
		_turnkP = .267,
		_turnkI = 0.00267,
		_turnkD = 2.67,
		_turnkF = 0; //There might be some error causing real world process we can take out with kF
	private static final double _TRACK_WIDTH = DRIVETRAIN.TRACK_WIDTH * CONVERSIONS.INCHES2METERS; //Jaci calls this wheelbase width
	private Timer _timer;
	private double _timeout = 5.0;
	private boolean _done = false;
    public DriveAlongProfile(Waypoint] points, double timeout) {
    	requires(Robot.drivetrain);
    	this._timer = new Timer();
    	this._timeout = timeout;
    	this._points = points.clone(); //Don't want a reference of points, I want a copy of it
    	this._buffer = new PIDOut();
    	this._pidSource = new PIDIn(() -> Robot.navx.getFusedAngle(), PIDSourceType.kDisplacement);
		this._angleController = new PIDController(DriveAlongProfile._turnkP,
													DriveAlongProfile._turnkI,
													DriveAlongProfile._turnkD,
													DriveAlongProfile._turnkF,
													this._pidSource,
													this._buffer);
		Trajectory.Config baseTrajectoryConfig = new Trajectory.Config(DriveAlongProfile._FIT_METHOD,
																		DriveAlongProfile._SAMPLES,
																		DriveAlongProfile._TIMESTEP,
																		DriveAlongProfile._MAX_VELOCITY,
																		DriveAlongProfile._MAX_ACCELERATION,
																		DriveAlongProfile._MAX_JERK);
		Trajectory baseTrajectory = Pathfinder.generate(this._points, baseTrajectoryConfig);
		TankModifier modifier = new TankModifier(baseTrajectory);
		modifier.modify(DriveAlongProfile._TRACK_WIDTH);
		this._leftTrajectory = modifier.getLeftTrajectory();
		this._rightTrajectory = modifier.getRightTrajectory();
		this._leftEncoderFollower = new EncoderFollower(this._leftTrajectory);
		this._rightEncoderFollower = new EncoderFollower(this._rightTrajectory);
    // Called just before this Command runs the first time
    protected void initialize() {
    	this._leftEncoderFollower.configureEncoder((int)Robot.drivetrain.getEncoderCounts(Robot.drivetrain.rearLeftTalon),
													(int)CONVERSIONS.REVS2TICKS,
													DRIVETRAIN.WHEEL_DIAMETER * CONVERSIONS.INCHES2METERS);
    	this._rightEncoderFollower.configureEncoder((int)Robot.drivetrain.getEncoderCounts(Robot.drivetrain.rearRightTalon),
    	this._leftEncoderFollower.configurePIDVA(DriveAlongProfile._drivekP,
													DriveAlongProfile._drivekI,
													DriveAlongProfile._drivekD,
													DriveAlongProfile._VELOCITY_RATIO,
													DriveAlongProfile._drivekA);
    	this._rightEncoderFollower.configurePIDVA(DriveAlongProfile._drivekP,
    	this._angleController.setInputRange(0, 360);
    	this._angleController.setContinuous(true);
    	this._angleController.setOutputRange(-.5, .5);
    	this._angleController.setAbsoluteTolerance(.2);
    	this._angleController.enable();
    	this._timer.start();
    // Called repeatedly when this Command is scheduled to run
    protected void execute()
    	double left = this._leftEncoderFollower.calculate((int) Robot.drivetrain.getEncoderCounts(Robot.drivetrain.frontLeftTalon));
    	double right = this._rightEncoderFollower.calculate((int) Robot.drivetrain.getEncoderCounts(Robot.drivetrain.frontRightTalon));
    	double heading = (this._leftEncoderFollower.getHeading() + this._rightEncoderFollower.getHeading()) / 2;
    	this._angleController.setSetpoint(Pathfinder.r2d(heading) % 360);
    	if (this._timer.get() >= this._timeout)
    		this._done = true;
    		return;
    	else if (left == 0 && right == 0 && this._buffer.output == 0)
    		this._done = true;
    		return;
    	left += this._buffer.output;
    	right -= this._buffer.output;
    	Robot.drivetrain.driveTank(left, right);
    // Make this return true when this Command no longer needs to run execute()
    protected boolean isFinished() {
        return this._done;
    // Called once after isFinished returns true
    protected void end()
    	Robot.drivetrain.stopMotors();
    // Called when another command which requires one or more of the same
    // subsystems is scheduled to run
    protected void interrupted()
    	this.end();
Here are the waypoints I generated. What could be causing this?
	public interface PROFILING
		public static final Waypoint]
				MID_TO_RIGHT_SWITCH =
					new Waypoint(0, 0, 0),
					new Waypoint(0.288 * CONVERSIONS.INCHES2METERS, 11.167 * CONVERSIONS.INCHES2METERS, Pathfinder.d2r(357.04)),
					new Waypoint(1.163 * CONVERSIONS.INCHES2METERS, 22.333 * CONVERSIONS.INCHES2METERS, Pathfinder.d2r(353.98)),
					new Waypoint(2.660 * CONVERSIONS.INCHES2METERS, 33.500 * CONVERSIONS.INCHES2METERS, Pathfinder.d2r(350.71)),
					new Waypoint(4.847 * CONVERSIONS.INCHES2METERS, 44.667 * CONVERSIONS.INCHES2METERS, Pathfinder.d2r(347.07)),
					new Waypoint(7.839 * CONVERSIONS.INCHES2METERS, 55.833 * CONVERSIONS.INCHES2METERS, Pathfinder.d2r(342.82)),
					new Waypoint(11.845 * CONVERSIONS.INCHES2METERS, 67.000 * CONVERSIONS.INCHES2METERS, Pathfinder.d2r(337.51)),
					new Waypoint(17.279 * CONVERSIONS.INCHES2METERS, 78.167 * CONVERSIONS.INCHES2METERS, Pathfinder.d2r(330.20)),
					new Waypoint(25.206 * CONVERSIONS.INCHES2METERS, 89.333 * CONVERSIONS.INCHES2METERS, Pathfinder.d2r(318.07)),
					new Waypoint(46.516 * CONVERSIONS.INCHES2METERS, 100.5 * CONVERSIONS.INCHES2METERS, Pathfinder.d2r(270.00))
				MID_TO_LEFT_SWITCH =
					new Waypoint(-0.011 * CONVERSIONS.INCHES2METERS, 26.834 * CONVERSIONS.INCHES2METERS, 0),
					new Waypoint(-3.966 * CONVERSIONS.INCHES2METERS, 66.548 * CONVERSIONS.INCHES2METERS, 6.0621),
					new Waypoint(-15.511 * CONVERSIONS.INCHES2METERS, 106.938 * CONVERSIONS.INCHES2METERS, 5.85),
					new Waypoint(-25.547 * CONVERSIONS.INCHES2METERS, 117.430 * CONVERSIONS.INCHES2METERS, 5.05),
					new Waypoint(-42.938 * CONVERSIONS.INCHES2METERS, 120.188 * CONVERSIONS.INCHES2METERS, 3.14),
I believe you cannot run Pathfinder.generate on the roborio – it takes almost 50s to generate some profiles. Instead, you need to pre-generate the profile and write them to file and load from there instead.
To elaborate on what Dustin said, you can generate profiles on the RIO, however as he said some profiles (likely yours included, just looking at the long list of points) will take some time to generate. A strategy some teams have used is taking some sort of hash of the path and path settings and saving the file using that as the name. Then, they can check if that file exists and if it does, load that instead of regenerating. You can also generate completely on your computer then deploy the files over yourself.
We calculate our paths on the rio in robotInit. Our paths are much simpler with fewer waypoints than yours so as others have said your paths may take too long to compute. github Used successfully for auto at our first competition (mainly center switch auto).
