Reprogramming the Box
alright, so one of our mentors mentors another team in our county as well, so he brought our control board over to their team to use with thier robot. on friday we got it back, but the team in it has been switched from 1591 to 3015 (obviously so it could work for that team). how do i change it back? is it something with the box’s IP adress?
If you mean one of the old IFI controllers than there should be some switches that are labeled team number that you can adjust. If you mean the cRio, which is more likely, than you need to follow the instructions in the manual located at http://www.usfirst.org/roboticsprograms/frc/content.aspx?id=14532.
Edit: It is in chapter 5, the cRio instructions start on page 7.
thank you for the help! i got it working now
