Request for Pit Scouting data from CMP please
There is a small crowd that would like to see a couple of CMP bot attributes pulled into the Scouting Database Visualization for a bit of analysis. In order to do that, we need to find some teams that would be willing to share their pit scouting data. I don’t need all the data, just team #, drive train, and whether the bot has a turret or not, formatted something similar to this:
The data can be in any sort of flat file, Excel or a Google sheet. If your team did pit scouting at CMP and are willing to share, please PM me with any questions and/or your scouting data. Once every bot has at least one related pit scouting record, I’ll pull it into the Rapid React Scouting Database Viz. Duplicate records are welcome because the more teams that help provide data, the better. It helps to ensure each robot is assigned the correct drive train and type of shooter.
Thanks!
I can get you almost all the teams in hopper (there may be 1 or 2 we missed)
Here you go, most of Hopper:
team_key,length,width,height,weight,drivetrain,external_intake,retract_intake,cargo_scorer,vision,auto_location,auto_drives,auto_shots_high,auto_shots_low,climb_height,climb_time
    frc11,33.0,26.0,0.0,119.0,Tank w/ Omni corners,True,True,Fixed Single Flywheel Tall,True,No Preference,True,2,0,4,About 15sec
    frc1111,30.0,30.0,0.0,115.0,Swerve,True,True,Fixed Multi Flywheel Tall,True,Near Edges of Field (2),True,4,0,2,About 10sec
    frc1339,26.0,30.0,0.0,125.0,Tank w/ Omni corners,True,True,Fixed Multi Flywheel Tall,False,Near Edges of Field (2),True,4,0,4,About 15sec
    frc148,26.5,26.5,0.0,110.0,Swerve,True,True,Turreted Multi Flywheel Tall,True,No Preference,True,5,0,4,About 05sec or less
    frc1538,29.0,29.0,46.0,124.0,Tank,True,True,Fixed Single Flywheel Tall,True,Near Edges of Field (2),True,5,0,2,About 05sec or less
    frc1574,29.0,29.0,120.0,125.0,Swerve,True,True,Fixed Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,4,About 15sec
    frc1625,30.0,29.0,38.0,107.0,Tank w/ Omni corners,True,True,Turreted Single Flywheel Tall,False,Near Edges of Field (2),True,5,0,4,About 30sec +
    frc1678,27.0,24.0,0.0,120.0,Swerve,True,True,Fixed Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,4,About 10sec
    frc1706,33.0,25.0,44.0,124.0,Swerve,True,True,Turreted Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,3,About 10sec
    frc177,30.0,25.0,47.0,101.0,Tank,True,True,Fixed Multi Flywheel Tall,True,No Preference,True,3,0,4,About 05sec or less
    frc180,29.9,29.9,0.0,124.0,Swerve,True,True,Fixed Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,3,About 05sec or less
    frc1807,32.0,28.0,31.0,125.0,Tank,True,True,Fixed Multi Flywheel Tall,True,No Preference,True,3,0,4,About 15sec
    frc201,30.0,30.0,48.0,110.0,Swerve,True,True,Fixed Multi Flywheel Short,True,No Preference,True,5,0,4,About 20sec
    frc2052,30.0,30.0,48.0,124.0,Swerve,True,True,Fixed Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,4,About 15sec
    frc2135,30.0,30.0,38.0,124.0,Tank,True,True,Fixed Multi Flywheel Tall,True,No Preference,True,3,0,4,About 15sec
    frc2202,31.0,28.0,51.0,118.0,Swerve,True,True,Fixed Multi Flywheel Short,True,Near Edges of Field (2),True,5,0,4,About 30sec +
    frc2252,32.0,28.0,52.0,124.0,Tank,True,True,Turreted Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,4,About 15sec
    frc2443,31.0,28.0,57.0,137.0,Tank w/ Omni corners,True,True,Fixed Single Flywheel Short,True,Near Edges of Field (2),True,3,0,4,About 30sec +
    frc2502,32.0,27.0,0.0,123.0,Tank,True,True,Turreted Multi Flywheel Tall,True,Near Edges of Field (2),True,4,0,0,About 20sec
    frc2614,0.0,0.0,0.0,125.0,Swerve,True,True,Turreted Single Flywheel Tall,True,Near Edges of Field (2),True,5,0,4,About 20sec
    frc2767,29.0,29.0,40.0,124.0,Swerve,True,True,Turreted Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,4,About 25sec
    frc2771,29.0,29.0,0.0,124.0,Swerve,True,False,Fixed Multi Flywheel Short,True,No Preference,True,2,0,0,About 15sec
    frc2832,28.0,28.0,40.0,110.0,Swerve,True,True,Fixed Single Flywheel Tall,True,No Preference,True,2,0,2,About 05sec or less
    frc2839,27.0,32.0,0.0,109.0,Tank,False,False,Turreted Multi Flywheel Short,True,No Preference,True,1,0,2,About 05sec or less
    frc2883,28.0,32.0,46.0,124.0,Tank,True,True,Turreted Single Flywheel Tall,True,Near Edges of Field (2),True,4,0,0,About 20sec
    frc2905,0.0,0.0,0.0,0.0,Mecanum,True,True,Fixed Multi Flywheel Tall,True,No Preference,True,2,0,4,About 30sec +
    frc2976,26.0,26.0,47.0,123.0,Swerve,True,True,Fixed Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,3,About 10sec
    frc2992,31.0,28.0,44.0,124.0,Swerve,True,True,Turreted Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,4,About 15sec
    frc302,28.0,27.0,0.0,124.0,Swerve,True,True,Fixed Multi Flywheel Short,True,No Preference,True,5,0,4,About 15sec
    frc3128,25.0,21.0,0.0,120.0,Tank,True,True,Fixed Single Flywheel Short,True,Near Edges of Field (2),True,3,0,0,About 15sec
    frc3322,29.0,29.0,0.0,112.0,Tank,True,True,Fixed Single Flywheel Tall,True,Near Edges of Field (2),True,4,0,3,About 15sec
    frc3478,0.0,0.0,1111.0,124.0,Mecanum,True,True,Turreted Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,4,About 20sec
    frc3512,32.0,27.0,0.0,122.0,Tank w/ Omni corners,True,True,Fixed Multi Flywheel Tall,True,Near Edges of Field (2),True,3,0,4,About 20sec
    frc3538,27.0,27.0,41.0,124.0,Tank,True,True,Turreted Multi Flywheel Tall,True,No Preference,True,5,0,4,About 10sec
    frc4063,27.0,33.0,42.0,124.0,Tank,True,True,Fixed Multi Flywheel Tall,False,No Preference,True,2,0,2,About 15sec
    frc4201,39.0,33.0,0.0,119.0,Tank,True,True,Turreted Multi Flywheel Tall,True,No Preference,True,5,0,3,About 10sec
    frc4213,28.0,26.0,44.0,107.0,Swerve,True,True,Fixed Single Flywheel Short,True,No Preference,True,4,0,4,About 20sec
    frc4421,25.0,32.0,0.0,120.0,Any Other (Add note),True,True,Fixed Multi Flywheel Tall,False,No Preference,True,3,0,4,About 20sec
    frc4499,29.0,29.0,0.0,122.0,Swerve,True,True,Fixed Multi Flywheel Tall,True,No Preference,True,5,0,4,About 15sec
    frc4522,28.0,28.0,0.0,125.0,Swerve,True,True,Fixed Multi Flywheel Short,False,Near Driverstation (1),True,4,0,4,About 20sec
    frc4592,32.0,27.0,42.0,70.0,Tank,False,False,Any Other (Add note),False,Near Driverstation (1),True,0,0,4,About 15sec
    frc488,0.0,0.0,0.0,124.0,Swerve,True,True,Fixed Single Flywheel Tall,True,No Preference,True,2,0,4,About 15sec
    frc494,0.0,0.0,0.0,122.0,Mecanum,True,True,Fixed Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,4,About 10sec
    frc5006,26.0,26.0,0.0,121.0,Swerve,True,True,Fixed Single Flywheel Tall,False,No Preference,True,2,0,4,About 05sec or less
    frc5216,32.0,28.0,0.0,124.0,Swerve,True,True,Everybot Arm,False,No Preference,True,0,2,4,About 20sec
    frc525,30.0,29.0,0.0,112.0,Swerve,True,True,Fixed Single Flywheel Short,True,Near Edges of Field (2),True,4,0,4,About 20sec
    frc5454,32.0,28.0,0.0,125.0,Swerve,True,True,Turreted Multi Flywheel Tall,True,No Preference,True,3,0,4,About 15sec
    frc5505,26.0,32.0,0.0,121.0,Tank w/ Omni corners,True,True,Turreted Single Flywheel Short,True,No Preference,True,3,0,4,About 20sec
    frc5806,28.0,26.0,0.0,120.0,Tank,True,True,Fixed Multi Flywheel Tall,False,Near Driverstation (1),True,1,0,2,About 10sec
    frc5817,0.0,0.0,0.0,125.0,Tank,True,True,Turreted Multi Flywheel Tall,True,No Preference,True,2,0,2,About 15sec
    frc597,32.0,27.0,0.0,110.0,Tank,True,True,Fixed Single Flywheel Tall,True,No Preference,True,2,0,2,About 05sec or less
    frc6036,28.0,28.0,44.0,115.0,Swerve,True,True,Fixed Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,4,About 25sec
    frc6135,28.0,31.0,0.0,90.0,Tank,True,False,Fixed Multi Flywheel Tall,True,No Preference,True,3,0,0,!No Climb
    frc624,26.0,26.0,0.0,123.0,Swerve,True,True,Fixed Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,0,About 10sec
    frc6420,0.0,0.0,39.0,124.0,Tank,True,True,Fixed Single Flywheel Short,False,No Preference,True,2,0,4,About 20sec
    frc6424,30.0,27.0,45.0,124.0,Mecanum,True,True,Fixed Single Flywheel Short,True,No Preference,True,2,0,2,!No Climb
    frc6998,0.0,0.0,0.0,121.0,Mecanum,True,True,Turreted Single Flywheel Tall,True,Near Edges of Field (2),True,4,0,4,About 20sec
    frc7021,29.0,29.0,42.0,120.0,Tank w/ Omni corners,True,True,Turreted Single Flywheel Tall,True,No Preference,True,4,0,3,About 10sec
    frc7153,29.0,39.0,42.0,112.0,Mecanum,True,True,Fixed Single Flywheel Tall,True,No Preference,True,2,0,2,About 05sec or less
    frc7315,0.0,0.0,1.0,75.0,Swerve,True,True,Everybot Arm,False,No Preference,True,0,1,2,About 10sec
    frc7617,27.0,23.5,42.0,124.5,Mecanum,True,True,Fixed Multi Flywheel Tall,False,No Preference,True,2,0,2,About 10sec
    frc7848,0.0,0.0,43.0,0.0,Tank,True,False,Fixed Single Flywheel Tall,False,No Preference,True,1,0,2,About 05sec or less
    frc8037,0.0,0.0,0.0,120.0,Tank w/ Omni corners,True,True,Fixed Single Flywheel Tall,False,No Preference,True,2,0,2,About 15sec
    frc8159,85.0,75.0,130.0,110.0,Tank w/ Omni corners,True,False,Fixed Single Flywheel Tall,True,No Preference,True,1,0,4,About 30sec +
    frc829,28.0,28.0,30.0,110.0,Swerve,True,True,Fixed Multi Flywheel Tall,True,Near Edges of Field (2),True,5,0,4,About 25sec
    frc8575,34.0,36.0,46.0,85.0,Tank,True,True,Fixed Single Flywheel Short,False,No Preference,True,2,0,2,About 10sec
    frc8701,28.3,29.0,3.0,110.0,Tank,True,True,Fixed Single Flywheel Tall,True,No Preference,True,2,0,3,About 20sec
    frc8739,32.0,26.0,43.0,115.0,Tank,True,True,Fixed Multi Flywheel Tall,True,No Preference,True,1,0,2,About 20sec
    frc8745,32.0,27.0,0.0,109.0,Tank,True,False,Turreted Multi Flywheel Tall,True,Near Edges of Field (2),True,2,0,2,About 05sec or less
    frc8822,0.0,0.0,0.0,106.0,Tank,True,True,Fixed Single Flywheel Short,False,Near Driverstation (1),True,0,0,2,About 10sec
    frc8825,0.0,0.0,0.0,75.0,Tank,True,True,Everybot Arm,False,Near Driverstation (1),True,0,1,4,About 10sec
Common folks, I know a few more of you have pit data out there …
We got most teams on Roebling.
Roebling Data
Team Number,What Kind of drivetrain?,Do you have a turret?
41,Tank Drive,No
67,Swerve,No
107,Swerve,No
115,Tank Drive,Yes
176,Tank Drive,Yes
230,Tank Drive,No
340,Swerve,No
359,Swerve,Yes
836,Swerve,No
1218,Swerve,Yes
1293,Tank Drive,No
1468,Tank Drive,No
1511,Swerve,No
1701,Tank Drive,No
1902,Tank Drive,No
1923,Tank Drive,No
1939,Tank Drive,No
1987,Swerve,No
2016,Tank Drive,No
2075,Tank Drive,Yes
2199,Swerve,No
2212,Kit of Parts,No
2338,Tank Drive,No
2341,Tank Drive,Yes
2471,Swerve,No
2478,Tank Drive,Yes
2531,Mecanum,No
2834,Swerve,Yes
2869,Kit of Parts,No
3075,Swerve,Yes
3182,Tank Drive,No
3197,Swerve,No
3310,Swerve,No
3374,Tank Drive,Yes
3467,Swerve,No
3534,Swerve,No
3539,Swerve,Yes
3620,Swerve,Yes
3636,Kit of Parts,No
4013,Tank Drive,No
4020,Swerve,No
4130,Tank Drive,No
4143,Swerve,No
4265,Swerve,Yes
4362,Tank Drive,Yes
4451,Tank Drive,No
4481,Tank Drive,No
4488,Swerve,No
4593,Tank Drive,No
4607,Tank Drive,No
4775,Mecanum,No
4795,Tank Drive,No
4829,Swerve,No
4930,Tank Drive,No
5437,Swerve,No
5712,Swerve,No
5813,Tank Drive,No
5827,Swerve,No
5895,Tank Drive,No
5900,Tank Drive,No
5913,Tank Drive,Yes
5940,Swerve,No
6078,Mecanum,Yes
6328,Tank Drive,No
6800,Swerve,Yes
6838,Swerve,No
7407,Swerve,No
7457,Kit of Parts,No
7483,Tank Drive,No
7485,Tank Drive,No
8717,Tank Drive,No
8788,Mecanum,No
8840,Tank Drive,No
8853,Tank Drive,No
8861,Tank Drive,No
1 pit scouting file has been received from each of the following divisions so far: Newton, Roebling, Galileo and Hopper.
Additional Newton data
Newton Data
Team,Drivetrain,Turret
27,Swerve,FALSE
51,Swerve,FALSE
111,Swerve,FALSE
114,Swerve,TRUE
166,Swerve,FALSE
365,Tank,TRUE
399,Tank,FALSE
573,Tank,TRUE
587,Swerve,TRUE
623,Mecanum,FALSE
818,Tank,TRUE
865,Tank,FALSE
973,Tank,TRUE
1153,Tank,FALSE
1325,Tank,TRUE
1493,Swerve,FALSE
1533,Mecanum,TRUE
1640,Swerve,TRUE
1676,Tank,FALSE
1684,Swerve,FALSE
1710,Swerve,FALSE
1711,Swerve,FALSE
1730,Swerve,FALSE
1787,Tank,FALSE
1825,Tank,FALSE
1986,Swerve,FALSE
2054,Tank,TRUE
2096,Tank,TRUE
2122,Swerve,FALSE
2412,Swerve,TRUE
2486,Swerve,FALSE
2582,Tank,FALSE
2872,Tank,FALSE
2910,Swerve,FALSE
2930,Swerve,FALSE
2987,Tank,FALSE
2990,Tank,FALSE
3005,Swerve,TRUE
3015,Swerve,TRUE
3065,Tank,FALSE
3196,Other,FALSE
3339,Swerve,TRUE
3461,Tank,TRUE
3489,Tank,FALSE
3630,Swerve,FALSE
3847,Swerve,FALSE
4206,Swerve,FALSE
4342,Swerve,FALSE
4391,Swerve,FALSE
4392,Swerve,TRUE
4909,Swerve,FALSE
5013,Swerve,FALSE
5050,Tank,FALSE
5098,Tank,TRUE
5166,Swerve,FALSE
5242,Tank,FALSE
5414,Tank,FALSE
5458,Tank,FALSE
5526,Swerve,FALSE
5587,Tank,TRUE
5804,Swerve,FALSE
5987,Swerve,FALSE
6560,Tank,TRUE
6844,Tank,FALSE
7034,Tank,FALSE
7094,Mecanum,FALSE
7157,Swerve,FALSE
7285,Tank,TRUE
7421,Tank,TRUE
7527,Tank,FALSE
8709,Tank,FALSE
8711,Mecanum,FALSE
8732,Swerve,FALSE
8768,Tank,FALSE
8848,Tank,FALSE
8885,Mecanum,FALSE
(sorry Liam I beat you to the punch (and also fixed a mistake on 1533’s DT))
Ope lol well now it’s here too
