Reset the Roborio Help!
Please Help! What do I need to do to the robot to get java back on it and reimage it. I know how to reimage once everything else is done. I do not have a clue how to get the basics back on. Where do I get the stuff? Help!
I think you should follow those steps : https://wpilib.screenstepslive.com/s/currentCS/m/getting_started/l/144984-imaging-your-roborio
The lastest WPI plugins for eclipse take care of installing java on the RoboRIO if it’s not there.
So, update your eclipse programs, use the National Instruments RoboRIO imaging tool, and you’re good to go.
Java is preinstalled on the roboRIO images for 2018. You should not need to install it manually.
