You may want to consider using the Current Mode control of a CAN enabled Jaguar. This will create less waste heat in your motor, assuming you properly tune the PID parameters.
I’m using the parameters found here, please let me know if I’m looking at the wrong motor.
You should expect to use about 6 amps to develop 6 Nm with this motor. It uses 22 Amps to generate 22.5 Nm at stall, so a rough pass is 6 Nm * ((22 A) / (22.5Nm)) = ~6Amps. The no-load current (which is really just another word “the sum of the parasitic torques in the system”) is small enough that I’m willing to ignore it for the time being.
With a “perfect” motor controller, you will apply a perfectly flat 6 amps. The motor’s resistance is roughly half an ohm, so your best case is (6 A)^2 * .5 ohms = 18 Watts.
Any imperfections in the motor controller will cause that current to oscillate a bit and become less efficient. For example, lets take one that applies 12 Amps half the time, and 0 amps the other half. Then our heating becomes (12 A) ^2 * .5 ohms * .5 duty = 36 Watts.
Worst case scenario, we’d expect something approaching stall current: (22 A)^2 * .5 ohms * (6/22) duty cycle = 66 Watts. This is 3.6 times the heat output!
The “flatness” of the current is a function of the ratio of the time constants of the motor and the motor controller. The faster the controller is, with respect to the motor, the flatter the current waveform. The flatter the current waveform, the more efficient the use of that current.
I don’t know what the time constant of this particular motor is, so I can not calculate where victors and jaguars fall on the continuum. However, the Jaguar’s time constant is over a 100 times faster.
Note that for this, I’ve assumed that the mechanical time constants are WAY slower than all of the electrical time constants. As long as you don’t see any twitching, this is likely a safe assumption.
