Resizing problem
I am using iMovie too put together my scenes from 3ds Max. how do i resize the file to the required size.
compressor. You need to have the NTSC quicktime format. The size needs to be 720X480.
Compressor is part of Final Cut Pro/Final Cut Studio, and since you’re using iMovie, you probably don’t have it.
Which version of iMovie?
If you have '08, you’ll use the “Export to Movie” command, which is cmd-E. It’s pretty self-explanatory.
I believe '06 and earlier had a “Share” command that was functionally identical to an export command. Choose QuickTime and select your options from the file save dialog’s settings button.
iSquint and VisualHub work well.
iSquint is free, VisualHub is not.
Jacob
