Retrieving Code
Hello, I was curious if there was anyway to pull code off the RC? Or if anyone has a program they made that can do it??\
Thanks in advance,
POPO
Check the IFI site, there is a tool.
However, you’re only gonna get (at best) a functional binary, you won’t be able to get the source.
Felix is correct. You can get the hex file back off of it using a tool from IFI, but that won’t get you the C source that was used to make it. You might be able to get a disassembler for that code, but that will still only get you PIC18F assembler code.
