Rev 2m Distance Sensor Error
I am trying to connect the 2m Distance sensor via I2C. Rev just released an updated maven/vendordeps file Releases · REVrobotics/2m-Distance-Sensor · GitHub 1 that is supposed to fix the Port to 2020 issue and I downloaded those files and put them in the appropriate locations. However, I’m still getting the same error. The code builds fine, but the Driver Station won’t run it.
ERROR  1  Unhandled exception: java.lang.UnsatisfiedLinkError: ‘void com.revrobotics.jni.VL53L0XJNI.Init(int, int)’  com.revrobotics.jni.VL53L0XJNI.Init(Native Method)
Warning at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:291): Robots should not quit, but yours did!
ERROR  1  The startCompetition() method (or methods called by it) should have handled the exception above.  edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:293)
Warning at edu.wpi.first.wpilibj.IterativeRobotBase.printLoopOverrunMessage(IterativeRobotBase.java:276): Loop time of 0.02s overrun
It would appear that there’s another version coming to fix this: https://github.com/REVrobotics/2m-Distance-Sensor/commit/17ed75de33b58e53590a333b841297a1b11dd38a
Continuing the discussion from Rev 2m Distance Sensor Error:
Yep the update fixed that. Now I’m just stuck with the new error
Error initializing Rev 2M device on port Onboard. Please check your connections
