Problem: position reading spontaneously begins to flicker between 0 and the accurate position reading. During some bouts (this occurred a number of times), the absolute encoder position read 2e13 and 2e-13.
Setup: absolute encoder connected to spark max (through the encoder adapter).
Frequency of occurrence: Once every couple hours of testing. Then we hit our heads against the wall and redeploy (see additional notes).
Additional Notes: After redeploying, the flickering stops and normal readings resume.
Testing so far: we tried switching out the encoder adapter (didn’t help).
Is it a faulty spark max, or does the redeploying fix suggest otherwise?
(also asked in discord, will post answers here if I get any)
