Rev Blinkin example code
Does any team perhaps have any example code for the rev Blinkin with 12v addressable rgb strips for command base programming?
What are you trying to do? What have you tried? What about it isnt working? How do you have things wired?
Same questions ^^
I made a helper class for this a while ago.
BlinkinLEDController.java (6.2 KB)
We were trying to figure out command based in 2020, but this is the subsystem we used…
Does anyone have code that links up with the colorsensorv3 with the Blinkin for command based programming?
