REV Blinkin won't turn on
When I plug in the blinkin the 5v and 12v light will light up, however the status light won’t light up and the strip won’t light up either.
Your brightness looks to be all the way down, which isn’t going to help matters.
I just checked it and it was all the way up on max brightness
If you haven’t yet, try a factory reset. The procedure is in the user guide. When we tried to use one we found it occasionally got “stuck” to where only a factory reset would bring it back.
I just factory reset it and only two single LEDs lit up. I even tried different strips, even a brand new one, and those would not even light up.
