REV CNC Field Flat Packs
We have finally finished flat packing all the REV field elements into 4’x8’ sheets for cutting, and I wanted to release the flat packs for anyone else who might be cutting them. A full field requires 40 sheets of 1/2" OSB or plywood (I’d recommend OSB), 1 per Amp, 6 per Speaker, and 13 per stage. We packed 2 speakers together into 12 sheets, so anyone making a single speaker would need to re nest and might need 7 sheets. The Speaker and Amp are step files, the stage is 1 dxf file per sheet.
Happy building!
2024 Field Flats.zip (1.9 MB)
@Patrick3357 I’m not sure if you saw, but there are flat-packs in the onshapes already set for 4x8’s for cutting.
https://cad.onshape.com/documents/9611efd632c14d1acbc60a5f/w/4e5fd12e42c93d128d42f05a/e/fde73e4de0d8f7f1523c88f0
Wow, How did we miss that?
Thanks Greg.
Looks like some parts have gotten moved around on the Stage/speaker tab.
Haven’t made the parts yet but did rearrange them in Fusion 360.
