Rev Ion Sprocket and Bearing Block won't align
We cannot figure out how these two
Pieces are supposed to go together. The spline teeth are always off. Are we nuts?
This is the 1x2 MAXSpline Bearing Block behind it, right? Turn it 90 degrees from how you have it - the holes centered above/below the spline pattern on the block line up with the center of the 3 hole pattern on either side in the gear. It means you’re attaching it to the sprocket with two bolts - and those two holes have recesses on the back side for the bolt head, which we’ve found to be a great feature for mounting!
Thank you.
