REV Lift Kit Missing Component
Our team is having an issue with the motor mechanism on the REV lift kit. The hex output shaft that protrudes beyond the gearbox is not long enough to serve as a spindle onto which the elevator lifting cord is wound. Is there an extension piece that can be bought, and if not by what other method can this issue be solved.
If it’s a Versaplanetary you can buy a female output shaft and then cut a hex shaft to your desired length.
if you cut a 1/4-20 bolt and thread it into the output shaft and also thread some T-Hex shaft and screw them together you can extend the shaft
The REV lift kit doesn’t include a motor/gearbox. . Which gearbox are you using? If you give us some information, we can do what we can to help you.
