REV Max Swerve replacement
What is the easiest way to replace the spark flex without completely disassembling the swerve module?
The only way you can replace the spark flex is by tanking the module apart. You don’t need to take it all apart, just remove the three bolts holding the module together. Than, take off the vortex and flex and replace them.
Thank you. Was really hoping to avoid that, but I guess not
