Hi CD! I have a question about the newest version of the REV Maxplanetary gearboxes. We received one today and when we went to assemble it, the #10-32 holes that attach the side plates to the middle plate do not align. I have tried to reassemble by attahcing different parts in a different order, but to no avail. Here are some pictures of the issue. Is there a workaround, or is this a manufacturing issue?
any advice offered is appreciated. We have another still in the box and will verify if this issue exists with the other one. Is this a case of skill issue or are we forgetting something? please let me know and thank you in advance!
Thanks everyone for the dms and possible answers! Turns out one of the bevel gears (the one that does not have a through bore) was a few thou oversized where the small radial bearing seats, giving the illusion we made it correctly but it needed an arbor press to actually slide into place. This is an isolated issue, as we assembled the other kit no problem. Thanks again CD!
this is the bearing, and it is supposed to be seated closer to the gear. Thanks for catching this, it looks normal until you see how it is supposed to look. For reference, the face of the shaft is supposed to be coplanar to the far face of the radial bearing, and we needed to give it a press to fit it there. Thanks!
