Rev Servo Power Module Legal?
Is the Rev Servo Power Module, Part REV-11-1144, legal for use with a legal 6V linear actuator such as the ones provided by WCProducts (ie part WCP-0410)? I have reviewed the rules and am not sure of the answer. We will power the Rev Power Module off the PDH with a 20 amp or less breaker.
If we run the linear actuator straight off the Rio, it doesn’t have enough power.
The REV-11-1144 is explicitly called out as a legal option to provide more current to 6v PWM servos. Assuming the linear servo you listed is in fact 6v (the product page doesn’t actually call out 6v, but I suspect it is user guides does) you should be okay, as it it a COTS product.
