This is my first time using chief Delphi, so I’m not really sure how this works. I need some help regarding the rev through bore encoder. My goal is to get it to return a value to shuffleboard. I’ve done this with an encoder from US digital. I’m running the same code I did with that one. I don’t know if I need to program it differently, but or not. we are using TalonSRX not a spark, we are using the “alternate encoder adapter” from REV to connect to the Talon. When I plug the encoder into the talon it doesn’t return a value, and depending on what talon I plug it into, I don’t know why, the LEDs either: flashes red from right to left, turn off, or, when i drive the motor in the opposite direction, both flash red like its driving backwards. Another thing that happens is as im plugging in the encoder all of the connected talons LEDs turn off for a second.
Here is the code im running, in case that is the issue:
