Edit: It turned out the build.gradle had implementation 'com.revrobotics.frc:SparkMax-java:1.5.4'
in it and so was downloading the older jar.
I’m working on updating our code for 2022, and since WPI’s SpeedController
interface is deprecated, we’re replacing that with the MotorController
. The problem is that a CANSparkMax
can’t be passed in as a MotorController
because even though the docs say it extends MotorController
in addition to SpeedController
, the jars I have on my computer don’t extend from MotorController
, resulting in a compilation error.
I’ve installed the new REVLib dependency online and then offline (through WPILib’s VS Code extension) with no luck. I’ve also run .\gradlew clean
several times just in case.
Any idea why the downloaded jars might be out of date? Is there an even newer link to install from?
Edit: I also deleted the .gradle
and gradle
folders after Fletch1373’s comment and generated the wrapper and built everything again, but the error persists.
