When I run my code, my zero offset isn’t applied and setZeroOffset returns the above error.
Our code is at GitHub - aesatchien/FRC2429_2025 at 2024_wpilib and, for convenience, the section causing issues is below:
class LowerCrank(Subsystem):
def __init__(self, container):
self.container = container
if wpilib.RobotBase.isReal():
self.sparkmax = CANSparkMax(constants.k_lower_crank_CAN_id, CANSparkMax.MotorType.kBrushless)
else:
self.sparkmax = SimCANSparkMax(constants.k_lower_crank_CAN_id, CANSparkMax.MotorType.kBrushless)
self.sparkmax.restoreFactoryDefaults()
self.encoder = self.sparkmax.getEncoder()
# radians
self.encoder.setPositionConversionFactor(math.tau / constants.k_lower_crank_dict["k_gear_ratio"])
self.encoder.setVelocityConversionFactor(math.tau / constants.k_lower_crank_dict["k_gear_ratio"])
self.abs_encoder = self.sparkmax.getAbsoluteEncoder()
self.abs_encoder.setPositionConversionFactor(math.tau / constants.k_lower_crank_dict["k_gear_ratio_after_planetaries"])
self.abs_encoder.setVelocityConversionFactor(math.tau / constants.k_lower_crank_dict["k_gear_ratio_after_planetaries"])
error_code = self.abs_encoder.setZeroOffset(constants.k_lower_crank_dict["k_abs_encoder_offset"])
print(f"set abs encoder offset to {constants.k_lower_crank_dict['k_abs_encoder_offset']}")
print(f"obtained error code {error_code}")
print(f"abs encoder registering {self.abs_encoder.getPosition()}")
# since everything's in radians, the encoders should agree
self.encoder.setPosition(self.abs_encoder.getPosition())
self.pid_controller = self.sparkmax.getPIDController()
self.pid_controller.setP(gain=constants.k_lower_crank_dict['kP'], slotID=0)
self.pid_controller.setI(gain=constants.k_lower_crank_dict['kI'], slotID=0)
self.pid_controller.setD(gain=constants.k_lower_crank_dict['kD'], slotID=0)
self.pid_controller.setIZone(math.radians(5), slotID=0)
self.pid_controller.setIMaxAccum(iMaxAccum=0.1, slotID=0)
wpilib.SmartDashboard.putNumber("kP", 0)
self.sparkmax.setSoftLimit(CANSparkMax.SoftLimitDirection.kForward, constants.k_lower_crank_dict["k_forward_limit"])
self.sparkmax.setSoftLimit(CANSparkMax.SoftLimitDirection.kReverse, constants.k_lower_crank_dict["k_reverse_limit"])
self.sparkmax.setIdleMode(CANSparkMax.IdleMode.kCoast)
self.sparkmax.burnFlash()
self.setpoint = self.get_angle()
self.counter = 0
