RevRobotics CANSparkMax Velocity to MetersPerSecond
How do I get MetersPerSecond using Neo CANSparkMax encoder?
Need this value for SwerveModuleState
You can ask the encoder to return its current velocity, and preform some math like the following:
driveEncoder.getVelocity() / Constants.GEAR_RATIO_DRIVE) * Math.PI * Constants.DRIVE_WHEEL_DIAMETER)
        / Constants.SECONDS_PER_MINUTE)
However, you can also tell the SparkMax to return its value from .getVelocity() to always be in Meters/Sec by setting a Velocity Conversion Factor, like the following:
driveRelEncoder.setVelocityConversionFactor((Constants.MK4_L2_DRIVE_REDUCTION * Math.PI * Constants.MK4_L2_WHEEL_DIAMETER)/60);
In both cases, you just times the Drive Ratio of the gearbox/swerve module, by Pi, and it’s wheel diameter.
