Ring Gear CAD File with Ratios
When someone is assembling a VersaPlanetary for a subsystem, they often waste time trying to find out what the designer intended for the overall gear ratio and sequence. Here is a ring gear file for SolidWorks where each configuration is labelled with a different ratio.
http://www.texastorque.org/ring-gear-with-ratios
Makes life a little easier.
Mr. Rip
