Ringer Dimensions
ARENA Section 6.3 says, “When inflated, each GAME
PIECE is approximately 32 inches across the outer diameter. Each toroid has an inner diameter of
approximately 13 inches, and a height of approximately 9-1/2 inches.”
Is anyone else having trouble that the ringers supplied in the KOP don’t match the dimensions shown? Ours measure 8.5" height.
We had a similar problem until we pumped our tubes up to the maximum PSI. At 2.5 PSI the tubes measure a perfect 9 1/2 by 9 1/2 inches.
We filled the tubes to this pressure using a sensitive pressure gauge and the KOP compressor.
