Riolog not displaying output
Hi, we’re using Java and we’ve been having problems using riolog. We had it working correctly last year, but it doesn’t seem to want to work now. We’re using Eclipse Mars and I made sure to check the console out option when we imaged the roborio at the beginning of build season. Does anyone know what could be happening? Is there some sort of bug with Mars, I remember it didn’t like deploying to 2015 roborios so is it the same kind of thing here? We’ve resorted to using smart dashboard to display values which is fine, but it can be a little finicky so we’d like to use riolog for simple printing. Thanks!
Are you trying to use it over wireless? If so have you downloaded the 16.4 radio config update (from 2/11) and reconfigured your radio? That update fixed a bug with rioLog over wireless.
https://usfirst.collab.net/sf/frs/do/viewRelease/projects.wpilib/frs.frc_radio_configuration_utility.frc_radio_configuration_utilit_0
