Hello, me and my team are having some communications error between the RoboRIO and the computer from were we send the code. We already tried changing the port were the router which we send the information and code via WIFI were the robot is connected, also we tried doing it with other computers and turning down their firewalls Any idea what could be the problem? and Any suggestions for solve it?
Did you run the radio configuration?
If you connect with USB does it work?
Are you connected to the robot’s wifi?
Can you navigate to 10.82.91.2? That should pull up the roboRIO’s web page
See if anything here helps:
