RoboRIO Deployment from Linux
Using open-ds and the proper radio configurations, you can deploy to the RoboRIO from Linux!
This might be useful for team members who mostly program on Linux, if you have vision/coprocessor code that is easier to develop on Linux but you also need to work on robot code, or if you want to set up a Raspberry Pi or other ARM64 system as a lab computer to do programming.
Networking setup
Connect power to the roboRIO
Plug a Power-Over-Ethernet splitter into the radio’s left port, and connect the power cable to power and the other cable to the roboRIO (by plugging in a normal Ethernet cable)
Plug an Ethernet cable into the radio’s right port and the other end into your computer (you may need a USB-to-Ethernet adapter if you’re doing this from a laptop)
WPILib Installation
Download the latest version of WPILib.
Extract the tarball and run WPILibInstaller
(inside the extraction directory). It will guide you through the steps to install WPILib.
Using the system VS Code/VSCodium (optional)
To use the system VS Code, open VS Code, open the Extensions tab, click the three dots, and click “Install from VSIX…”. Choose ~/wpilib/2024/vsCodeExtensions/vscode-wpilib-2024.1.1.vsix
Driver Station (open-ds) Installation
Note: open-ds is not the official driver station and may have missing features
To install open-ds, please install a JDK or JRE for Java 8 or later.
On Debian and Ubuntu, please install:
sudo apt install default-jdk
On other distros, consult your package manager documentation or package manager search tool.
If your distro does not provide a JDK, you can download a JRE from [Eclipse Temurin (AdoptOpenJDK)](https://adoptium.net/temurin/releases/?os=linux&package=jre).
Now, you can download the JAR for open-ds from GitHub Releases. I will provide an updated JAR, a .desktop
file, and a complete installer in the future, but for now, you can use the following command to launch the JAR:
java -jar open-ds-v0.2.4.jar
Phoenix Tuner X installation (optional)
(these instructions assume Ubuntu or Debian)
(this will install the Android version of Phoenix Tuner X)
First, install the Android rootfs and userspace libraries:
sudo apt install curl ca-certificates -y
curl https://repo.waydro.id | sudo bash
sudo apt install waydroid -y
sudo waydroid init
waydroid prop set persist.waydroid.multi_windows true
waydroid session stop
Now, download and install Phoenix Tuner X:
wget https://github.com/ethanc8/someblobs/releases/download/phoenix-tuner-x-2024.6.1.0/Tuner.X_2024.6.1.0_apkcombo.com.apk
waydroid app install "./Tuner X*.apk"
waydroid app launch com.ctre.phoenix_tuner
TODO
If any of you want to help me with this, please leave a comment!
- Support other ways to connect to the RoboRIO
- Direct via USB
- Direct via Ethernet (plug in to RoboRIO)
- Direct via RS-232 serial port (via USB adapter or GPIO)
- Wi-Fi to router
- Test on arm64 systems
- Support flashing the RoboRIO ([my notes](https://gist.github.com/ethanc8/57a26e21e87deb82e78bc89e5805b3e2))
- Support configuring the radio
- [ ] Determine other features supported by FRC Game Tools
- Start maintaining open-ds
- Make an installer for the Linux Game Tools
- Port to Android
