RoboRIO Error
Hello, when we try to deploy our code from Eclipse, we get this error:
BUILD FAILED
C:\Users\Developer\wpilib\java\current\ant\build.xml:209: Assertion failed boolean test.
Image of roboRIO does not match plugin.
Allowed image year: 2016 version: 19.
Actual image year: ImageRegExFail version ImageRegExFail.
RoboRIO needs to be re-imaged or plugins updated.
Do we need to update a plugin? And if so, how do we go about that? We are using a new roboRIO, and our code works with our 2016 roboRIO but not this years. Please help!
You need to update the Eclipse plugins
Thanks for letting us know! How do we update the Eclipse plugins? Thanks!
BetaBlues
Help -> Check for Updates
Make sure you’re installing the Talon API from Cross The Road Electronic’ site to be able to use them if you’re planning to:
You go to here and download and install the CTRE Toolsuite from Tech Resources tab. :slight_smile:
