I’ve been having some trouble programming/debugging the RoboRIO. This is the tail end of the output I see in the console when attempting to deploy:
get-target-ip:
[echo] Trying Target: roboRIO-488.local
Unknown host: roboRIO-488.local
[echo] roboRIO not found via mDNS, falling back to static USB
[echo] roboRIO not found via USB, falling back to static address of 10.4.88.2
BUILD FAILED
C:\Users\John\wpilib\java\current\ant\build.xml:45: Assertion failed boolean test.
roboRIO not found, please check that the roboRIO is connected, imaged and that the team number is set properly in Eclipse
I can ping roboRIO-488.local successfully. I can also read the files on the roboRIO via FTP.
In Window->Preferences->WPILib Preferences, my team number is set to 488.
The roboRIO has been imaged with the v23 image (and I can confirm with the tool). I can also see and operate the robot via the Driver Station.
By plugging in the USB cable, I am able to program the robot. Also, the debug environment seems to only try connecting to roborio-488.local, and doesn’t work via USB.
Is it possible to modify the WPI plugin to get the debug command to use an IP address target instead of the “roboRio-488.local” address? And if so, how?
Well, instead of modifying the plugins, I decided to modify my machine.
I edited my hosts file (C:\Windows\System32\drivers\etc\hosts) to include this line:
169.254.82.206 roboRIO-488.local
This allows deployment and debugging without modification of build scripts or anything… but is obviously somewhat fragile. Hopefully I can root cause the actual issue in the meantime.
This would be possible by modifying the ant script in the ~/wpilib/java/current/ant/ directory, but that’ll run into the same issue as a hosts workaround, which is that the roboRIO ip could change. As it is, we default to mdns, but fall back to static USB and old-style 10.te.am.2 if mdns isn’t found.
The problem I had there is while I could edit the ant script to deploy code, it seemed like Eclipse would always attempt to connect to “roboRio-488.local” when opening the connection to the remote debugger.
Well, you could theoretically make a new ant run config that runs the debug-deploy target, and a new remote debug configuration that connects to the remote jvm session. I haven’t tried it, but I just went and looked at the plugin source, and I think these are the parameters you’ll need to set:
Connection Type: Standard (Socket Attach)
Host: <YOUR IP HERE>
Port: 8348
No guarantees that these are the actual correct parameters, as I didn’t write any part of the plugin, but if I’m reading it correctly, then that’s what you’re looking for. If you’re interested in taking a look yourself (if that doesn’t work), then visit https://usfirst.collab.net/sf/projects/wpilib/ and follow the instructions to look at the source. The particular file I’m pulling this info from is eclipse-plugins/<long package name>.java/src/main/java/<more packages>/launching/JavaLaunchShortcut.java, in the getRemoteDebugConfig method. Hope that helps.
Reconfiguring the D-Link router with the “Bridge Configuration Utility” fixed us up. This tool came with the software update, and is in
C:\Program Files (x86)\National Instruments\LabVIEW 2014\project
