Hey all, I just firmware update a new roboRIO to firmware version 6.0.0f1 and image 2020v10 using a new install of FRC game tools. It appears to require Silverlight to connect to the configuration page now, which is strange as the other RIOs that I’ve not updated from 2019 don’t require this. Did I do something wrong?
Are you sure it’s currently on the 2020 image? It almost certainly shouldn’t be giving you the Silverlight configuration page. Try uploading code and see if it deploys properly.
I agree with @bobbysq. You should not require Silverlight anymore. Ensure you are not using Internet Explorer to access the Web Configuration anymore (which BTW, will only be helpful if you need to change the IP, I wouldn’t expect you to use that interface at all).
I tried reimaging again on the same computer and it worked thanks all
