Hi, I am the new programer for Corner Canyon Robotics. Our robot will only use the code from last year and not use any of my new code although eclipse says “BUILD SUCCESSFUL”. Also, we think it is the program but, our robot will twitch to the left in random intervals and for random amounts of time.
What we have tried:
- Replacing motor controllers
- Replacing all motors
3.Re-imaging roborio’
4.Updating firmware on roborio - Factory reset roborio
Some Specs:
- Laptop running windows 10
- Updated Robot Radio
CODE ON ROBORIO:
package org.usfirst.frc.team5071.robot;
import edu.wpi.first.wpilibj.DriverStation;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.PWM;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
The VM is configured to automatically run this class, and to call the
functions corresponding to each mode, as described in the IterativeRobot
documentation. If you change the name of this class or the package after
creating this project, you must also update the manifest file in the resource
directory.
public class OldRobot extends IterativeRobot {private RobotDrive robit;
private Talon talon;
private Joystick xbox;
private DriverStation station;
private boolean AButton, BButton, XButton, YButton, rightBumper, leftBumper, startButton, stopButton;
private double axisXleft, axisYleft, axisXright, axisYright, leftTrigger, rightTrigger;/**
- This function is run when the robot is first started up and should be
- used for any initialization code.
public void robotInit() {
xbox = new Joystick(0);
//0=front left 1=back left 2= front right 3= back right
robit = new RobotDrive(0,1);
talon = new Talon(2);
AButton = false;
BButton = false;
XButton = false;
YButton = false;
rightBumper = false;
leftBumper = false;
startButton = false;
stopButton = false;
public void disabledPeriodic() {
Scheduler.getInstance().run();
- This function is called periodically during autonomous
public void teleopInit() {
// This makes sure that the autonomous stops running when
// teleop starts running. If you want the autonomous to
// continue until interrupted by another command, remove
// this line or comment it out.
- This function is called when the disabled button is hit. You can use it
- to reset subsystems before shutting down.
public void disabledInit() {
talon.stopMotor();
This function is called periodically during operator control
AButton = xbox.getRawButton(1);
BButton = xbox.getRawButton(2);
XButton = xbox.getRawButton(3);
YButton = xbox.getRawButton(4);
rightBumper = xbox.getRawButton(5);
leftBumper = xbox.getRawButton(6);
stopButton = xbox.getRawButton(7);
startButton = xbox.getRawButton(8);axisXleft = xbox.getRawAxis(0);
axisYleft = xbox.getRawAxis(1);
leftTrigger = xbox.getRawAxis(2);
rightTrigger = xbox.getRawAxis(3);
axisXright = xbox.getRawAxis(4);
axisYright = xbox.getRawAxis(5);
talon.enableDeadbandElimination(true);
talon.set(0);
if(axisXleft < 0.1){
axisXleft = 0;
if(axisYleft <0.1){
axisYleft = 0;
if(axisXright < 0.1){
axisXright = 0;
if(axisYright <0.1){
axisYright = 0;
}// robit.arcadeDrive(-axisYleft, -axisXleft + axisYleft, true);
// Game drive
robit.tankDrive(-axisYleft, -axisYright, true);if (leftTrigger == 1) {
robit.drive(.7, axisXleft - axisYleft);
} else if (rightTrigger == 1) {
robit.drive(-.7, axisXleft - axisYleft);
} else {
robit.stopMotor();
if (AButton == true) {
talon.set(-.6);
} else if (BButton == true) {
talon.set(.2);
} else {
talon.set(0);
}// Lift
/*- if (leftTrigger == 1) { talon.set(-.2);
- Scheduler.getInstance().run(); } else if (rightTrigger == 1) {
- talon.set(.8); Scheduler.getInstance().run(); } else { talon.set(0);
// if (AButton == true) {
// talon.set(1);
// Timer.delay(5);
// talon.set(-1);
// Timer.delay(5);
// talon.set(0);
// } else {
// talon.set(0);
// Kill button
if (startButton == true) {
station.release();
- This function is called periodically during test mode
public void testPeriodic() {
LiveWindow.run();
public RobotDrive getRobit() {
return robit;
}public void setRobit(RobotDrive robit) {
this.robit = robit;
}public Joystick getXbox() {
return xbox;
}public void setXbox(Joystick xbox) {
this.xbox = xbox;
}public boolean isAButton() {
return AButton;
}public void setAButton(boolean aButton) {
AButton = aButton;
}public boolean isBButton() {
return BButton;
}public void setBButton(boolean bButton) {
BButton = bButton;
}public boolean isXButton() {
return XButton;
}public void setXButton(boolean xButton) {
XButton = xButton;
}public boolean isYButton() {
return YButton;
}public void setYButton(boolean yButton) {
YButton = yButton;
}public boolean isrightBumper() {
return rightBumper;
}public void setrightBumper(boolean rightBumper) {
this.rightBumper = rightBumper;
}public boolean isleftBumper() {
return leftBumper;
}public void setleftBumper(boolean leftBumper) {
this.leftBumper = leftBumper;
}public double getAxisXleft() {
return axisXleft;
}public void setAxisXleft(double axisXleft) {
this.axisXleft = axisXleft;
}public double getAxisYleft() {
return axisYleft;
}public void setAxisYleft(double axisYleft) {
this.axisYleft = axisYleft;
}public double getAxisXright() {
return axisXright;
}public void setAxisXright(double axisXright) {
this.axisXright = axisXright;
}public double getAxisYright() {
return axisYright;
}public void setAxisYright(double axisYright) {
this.axisYright = axisYright;
}public double getleftTrigger() {
return leftTrigger;
}public void setleftTrigger(double leftTrigger) {
this.leftTrigger = leftTrigger;
}public double getrightTrigger() {
return rightTrigger;
}public void setrightTrigger(double rightTrigger) {
this.rightTrigger = rightTrigger;
}public boolean isStopButton() {
return stopButton;
}public void setStopButton(boolean stopButton) {
this.stopButton = stopButton;
NEW CODE WE WANT TO DOWNLOAD:
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Victor;
public class NewDrive extends SampleRobot {
RobotDrive myDrive;
Joystick xbox;
myDrive = new RobotDrive(1,2,3,4);
xbox = new Joystick(1);
public void operatorControl() {
while (isOperatorControl() && isEnabled()) {
myDrive.tankDrive(axisYleft, axisYright);;
Timer.delay(0.01);
