We use NI’s roboRIOs to control our robot. However, all five of the roboRIOs have stopped functioning correctly in the span of one or two days.
We cannot connect to our target in LabVIEW. This was usually fixed when reimaging the RIO or reinstalling the firmware.
We have tried almost everything we could do:
we made sure the network address was correct
we swapped computers, swapped the cables
power recycled over and over
redid the electrical wiring
swapped the RIOs
and only discovered that all of our RIOsdo not work.
The interesting thing is that we still have comms, but we just cannot connect to the target.
The only thing in common with the RIOs was that they had the recent roboRIO 2022 v. 4.0 image installed on them, which is why we suspect an issue with the recent image.
and no, i have not used the ni max. I have just searched it up but i cant seem to find a document about that. Do you possibly have a link to the document?
also, do you know how it worked when the target ip address was set to be roboRIO-5411-FRC.local?
