In my limited experience, the 6 hours of unbag time in your shop is infinitely more productive than a similar amount of time at a regular event, because you can develop a plan, execute it without waiting on other teams, and bag again when you finish. (Trying to actually get anything productive done at events like CMP is ridiculous)
You get up to 3 robot access periods, and the minimum time consumed for unbagging is 30 minutes (i.e. if you unbag for 5 minutes, that counts as 30 minutes; but if you unbag for 43 minutes it counts as 43 minutes and is not rounded up), the total time for these 3 unbags (plus any time wasted when unbagging for < 30 minutes) must be less than 6 hours.
When you bag or unbag, you always need a non-student adult to sign the bag’n’tag form; just as is done on stop build day, and at events.
5.6.2 ‘Robot Access Period’ - Schedule
Teams may unlock their robot for a total of 6 hours during the 7-day period preceding any two-day event in which their team will be competing with their robot. The 6 hours may be broken up in any way the team wishes, with the exception that** no single access period may be shorter than 30 minutes** and the team may not have more than** 3 access periods** prior to each event. The robot must be locked up in between sessions and** this must be documented on the Robot Lock-Up Form each time**.
You can treat your unbag period as you would treat your robot at an event. You can use a static 45lbs of pre-fabricated materials to improve your robot while unbagged, however anything you use does count towards your total that you bring to the event. (i.e, if you left off a 45lb catapult, you can’t bring any spare parts to the event, even if you put the catapult on the robot during your unbag time). If you fabricate something during the unbag period, it is the same as doing so at the competition, and doesn’t count towards your limit.
Anything you take off your robot during an access period, which isn’t replaced during the same access period, becomes part of your 45lb allowance. You cannot split your robot in half, bag half-A and work on half-B, then unbag half-A and put half-B into the bag and work on half-A.
R18:
For Teams attending 2-Day Events, these FABRICATED ITEMS may be used during the Robot Access Period and/or brought to the Event, but the total weight may not exceed 45 lbs. FABRICATED ITEMS constructed during the Robot Access Period and bagged with the ROBOT are exempt from this limit.
