How do you add cameras to robot builder so you can put them on your Drivers Station Dashboard? We’ve added camera objects but want to also use an MjpegServer to switch between them via code. I’m told they won’t show on the dashboard if we do that.
You can just add them manually to your code rather than doing it in RobotBuilder. The “switched camera” will show on the dashboard if you do CameraServer.getServer(). See http://wpilib.screenstepslive.com/s/currentCS/m/vision/l/708159-using-multiple-cameras
