Hello Everyone, I’m a mentor with FRC1296 and I had a couple of questions about the Robot Characterization Tool…
Our drivetrain consists of 4 TalonFX motors, standard differential drive and six wheels.
Project Type: drivetrain
Control Type: CTRE
The auto-generated template has an entry for “encoderEPR” (Encoder edges-per-revolution). Should this value be 2048? I have seen some discussion that this needs to account for the gear ratio but there appears to be an attribute in the template for that named “gearing”.
The comment in the template says… # For the CTRE Mag Encoder, use 16384 (4 * 4096 = 16384)
So as far as I’m aware, edges-per-revolution account for a quarter-turn of a revolution (Encoders - Hardware — FIRST Robotics Competition documentation). This is why the comment indicates that they multiply by 4 since the encoder itself is a quadrature encoder.
I’m fairly sure that you should be using 2048 for the encoder EPR. This has somewhat been talked about in this thread as well so check it out!
Edges per revolution is the total number of signal transitions per rev. So, up and down are separate, as are A and B. So, a 100 pulses per rev quadrature encoder is 100 pulses x two channels x two states.
The reason for this is that is the highest possible positional information without interpolation and guessing the speed.
