Our robot code will crash whenever we call cancelAll(). I can get the error code but we call this for testing because we have different commands in different modes and we don’t want anything to break when we re-enable. I can send the error code later. By the way we are using the CommandScheduler (new command based stuff) and it crashes on the CommandScheduler.getInstance().cancelAll() call
What does the stacktrace have in it?
Error at java.base/java.util.LinkedHashMap$LinkedHashIterator.nextNode(LinkedHashMap.java:719): Unhandled exception: java.util.ConcurrentModificationException
at java.base/java.util.LinkedHashMap$LinkedKeyIterator.next(LinkedHashMap.java:741)
at edu.wpi.first.wpilibj2.command.CommandScheduler.cancelAll(CommandScheduler.java:378)
at frc.robot.Robot.autonomousInit(Robot.java:78)
at edu.wpi.first.wpilibj.IterativeRobotBase.loopFunc(IterativeRobotBase.java:220)
at edu.wpi.first.wpilibj.TimedRobot.startCompetition(TimedRobot.java:82)
at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:276)
at edu.wpi.first.wpilibj.RobotBase.lambda$startRobot$0(RobotBase.java:329)
at java.base/java.lang.Thread.run(Thread.java:834)
Looks like a bug in the API.
Their code:
public void cancelAll() {
for (Command command : m_scheduledCommands.keySet()) {
cancel(command);
The iterator.get method is structurally modifying the set.
I think that m_scheduledCommands.values() is what they should be iterating over to avoid it.
The structure of the m_scheduledCommands is a Map<Command, CommandState>. So the .keySet() is correct to get the Command. Should I just wait for an update?
