This year our team has a severe lack of experience members, as such I am currently the only programmer on our team and have no previous experience coding in FRC prior to the beginning of this year. I’ve attempted to follow the docs closely, but probably not to the degree I should have been. Thus, I’m sure there are a multitude of problems and bad practices in our code which could be causing the problem in the title above. Anyway our code will occasionally deploy, with the need for deploying multiple times before the code works, and even then it crashes or will just suddenly stop working altogether. This problem started a few weeks ago but I dumbly overlooked it. I’m considering rebuilding our code from the ground up to try and diagnose the issue, but given we only have a few days before we leave for competition I felt it a good idea to post here for any help before diving into that endeavor. If there is anyone who is willing to take a look or even point me in the right direction it would be greatly appreciated.
Here is our GitHub with all our robot code: GitHub
and here is the console log we get when deploying code to driver station
Thank you
Warning 0 [phoenix-diagnostics] Server shutdown cleanly. (dur:1578|0)
Warning 0 [phoenix] Library shutdown cleanly
Warning 0 [phoenix-diagnostics] Server shutdown cleanly. (dur:10|0)
********** Robot program starting **********
NT: server: client CONNECTED: 172.22.11.1 port 52599
CS: USB Camera 0: Connecting to USB camera on /dev/video0
Warning 44003 FRC: No robot code is currently running. Driver Station
********** Robot program startup complete **********
Warning 1 Loop time of 0.02s overrun
edu.wpi.first.wpilibj.IterativeRobotBase.printLoopOverrunMessage(IterativeRobotBase.java:359)
Warning at edu.wpi.first.wpilibj.IterativeRobotBase.printLoopOverrunMessage(IterativeRobotBase.java:359): Loop time of 0.02s overrun
Warning 1 SmartDashboard.updateValues(): 0.000350s
disabledInit(): 0.002998s
robotPeriodic(): 0.081509s
LiveWindow.updateValues(): 0.265728s
Shuffleboard.update(): 0.000116s
disabledPeriodic(): 0.003747s
edu.wpi.first.wpilibj.Tracer.lambda$printEpochs$0(Tracer.java:63)
Warning at edu.wpi.first.wpilibj.Tracer.lambda$printEpochs$0(Tracer.java:63): SmartDashboard.updateValues(): 0.000350s
