I run the code and the Driver station accepts it and allows it to run but when I press the buttons nothing happens? Pleas help ASAP
If I try to separate the Initializing of buttons from the button commands it fails to recolonize that they go together and created a whole mess of syntax errors
package org.usfirst.frc.team4284.robot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.buttons.JoystickButton;
import edu.wpi.first.wpilibj.buttons.Button;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
- The VM is configured to automatically run this class, and to call the
- functions corresponding to each mode, as described in the IterativeRobot
- documentation. If you change the name of this class or the package after
- creating this project, you must also update the manifest file in the resource
- directory.
RobotDrive Drive;
Joystick drivestick;
Joystick joystick;
int autoLoopCounter;
- This function is run when the robot is first started up and should be
- used for any initialization code.
public void robotInit() {
Jaguar FL = new Jaguar (5);
Jaguar BL = new Jaguar (2);
Jaguar FR = new Jaguar (3);
Jaguar BR = new Jaguar (4);
Drive = new RobotDrive(FL,BL,FR,BR);
drivestick = new Joystick(0);
joystick = new Joystick(1);
- This function is run once each time the robot enters autonomous mode
autoLoopCounter = 0;
- This function is called periodically during autonomous
/*if(autoLoopCounter < 100) //Check if we’ve completed 100 loops (approximately 2 seconds)
Drive.drive(-0.5, 0.0); // drive forwards half speed
autoLoopCounter++;
} else {
Drive.drive(0.0, 0.0); // stop robot
- This function is called once each time the robot enters tele-operated mode
public void teleopInit(){
- This function is called periodically during operator control
Drive.arcadeDrive(drivestick);
Button button1 = new JoystickButton(joystick, 1),
button2 = new JoystickButton(joystick, 2),
button3 = new JoystickButton(joystick, 3),
button4 = new JoystickButton(joystick, 4),
button5 = new JoystickButton(joystick, 5),
button6 = new JoystickButton(joystick, 6),
button7 = new JoystickButton(joystick, 7),
button8 = new JoystickButton(joystick, 8),
button9 = new JoystickButton(joystick, 9),
button10 = new JoystickButton(joystick, 10),
button11 = new JoystickButton(joystick , 11);
button1.whenPressed(new ElevatorOff());
button2.whenPressed(new ElevatorOn());
button3.whenPressed(new ElevatorReverse());
button4.whenPressed(new ArmsOut());
button5.whenPressed(new ArmsIn());
button6.whenPressed(new ArmsVerticalIn());
button7.whenPressed(new ArmsVarticalOut());
button8.whenPressed(new BlueLightShow());
button9.whenPressed(new LigthShowOn());
button10.whenPressed(new RedLightShow());
button11.whenPressed(new LightShowEnd());
- This function is called periodically during test mode
public void testPeriodic() {
LiveWindow.run();
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.command.Command;
public class ArmsIn extends Command {
@Override
protected void initialize() {
// TODO Auto-generated method stub
@Override
protected void execute() {
Talon LeftArm = new Talon(9);
Talon RightArm = new Talon(8);
LeftArm.set(1);
RightArm.set(-1);
try {
Thread.sleep(500); //stop for 1/2 second
} catch(InterruptedException ex) { // allows for interruption of the sleep period
Thread.currentThread().interrupt();
LeftArm.set(0);
RightArm.set(0);
@Override
protected boolean isFinished() {
return false;
@Override
protected void end() {
@Override
protected void interrupted() {
public class ArmsOut extends Command {
@Override
@Override
Talon RightArm = new Talon(9);
Talon LeftArm = new Talon(8);
LeftArm.set(-1);
RightArm.set(1);
try {
LeftArm.set(0);
RightArm.set(0);
@Override
return false;
@Override
@Override
public class ArmsVarticalOut extends Command {
@Override
@Override
Talon In_Out = new Talon(7);
Talon In__Out = new Talon(0);
In_Out.set(-1);
In__Out.set(-1);
try {
In_Out.set(0);
In__Out.set(0);
@Override
return false;
@Override
@Override
public class ArmsVerticalIn extends Command {
@Override
@Override
Talon In_Out = new Talon (7);
In_Out.set(1);
In__Out.set(1);
try {
In_Out.set(0);
In__Out.set(0);
@Override
return false;
@Override
@Override
import edu.wpi.first.wpilibj.Relay;
public class BlueLightShow extends Command {
@Override
@Override
Relay relay1 = new Relay(0);
Relay relay2 = new Relay(1);
relay1.set(Relay.Value.kOn);
relay2.set(Relay.Value.kOff);
@Override
return false;
@Override
@Override
public class ElevatorOff extends Command {
@Override
@Override
Jaguar Elevator1 = new Jaguar(5);
Jaguar Elevator2 = new Jaguar(0);
Elevator1.set(0);
Elevator2.set(0);
@Override
return false;
@Override
@Override
public class ElevatorOn extends Command {
@Override
@Override
Elevator1.set(.25);
Elevator2.set(.25);
@Override
return false;
@Override
@Override
public class ElevatorReverse extends Command {
@Override
@Override
Elevator1.set(-.25);
Elevator2.set(-.25);
@Override
return false;
@Override
@Override
public class LightShowEnd extends Command {
@Override
@Override
relay1.set(Relay.Value.kOff);
@Override
return false;
@Override
@Override
public class LigthShowOn extends Command {
@Override
@Override
relay1.set(Relay.Value.kReverse);
relay2.set(Relay.Value.kOn);
try {
Thread.sleep(5000); //stop for 1/2 second
//Turn on lights Blue and Green)
relay2.set(Relay.Value.kReverse);
try {
// Turns on blue and red lights
relay2.set(Relay.Value.kForward);
try {
@Override
return false;
@Override
@Override
public class RedLightShow extends Command {
@Override
@Override
@Override
return false;
@Override
@Override
Please and thank you
