Our team is doing vision processing for the first time, using an Nvidia Jetson TX1 to do our vision processing. Currently, we are connecting the camera and the Jetson to the network that we’re setting up using the radio in our lab. To run the Python OpenCV script on the Jetson, I simply SSH into the Jetson terminal from the driver station and run it before starting the robot program.
I’m a little unsure of how the network is set up at the field during competitions, and I know that radios cannot setup their home network on the field. I was wondering if I will still be able to SSH into the Jetson using its static IP and if I can use the same IP of the camera as I did when it was connected to the radio’s network. Also, is it legal to run a separate process such as SSH on the driver station or does the robot code need to start the Python script on the Jetson automatically?
