During the 2024 FRC competition season, our team encountered an issue with our robot during the state competition. Sometimes, it would stop listening to the driver’s input and drive in random directions. There was no perceivable pattern to the driving, it seemed entirely random. Our driver’s said that sometimes during the early stages of the issue, they were able to partially control the robot. Only the drive train was effected. The issue only occurred while the robot was using vision in the teleoperated period, but didn’t always occur while it was using vision. We removed the code that linked a button to using vision, and the issue didn’t occur.
The strangest thing about this issue, was that we encountered it before the competition, so reverted back to the branch in our code that had never had this issue before, but the issue kept occurring at the same frequency. Thusly, it is likely that the issue could be electrical.
We are using an Orange Pi 5 and a global shutter camera for vision. We replaced the driver station and controllers, but the issue is still occurring. We have never been able to recreate the issue on purpose, but can easily recreate the issue when we don’t want to.
Here is the vision code we use:
Vision:
- MIT License
- Copyright (c) PhotonVision
- Permission is hereby granted, free of charge, to any person obtaining a copy
- of this software and associated documentation files (the “Software”), to deal
- in the Software without restriction, including without limitation the rights
- to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
- copies of the Software, and to permit persons to whom the Software is
- furnished to do so, subject to the following conditions:
- The above copyright notice and this permission notice shall be included in all
- copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
- AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
- OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
- SOFTWARE.
package frc.robot;
import static frc.robot.Constants.VisionConstants.*;
import edu.wpi.first.math.Matrix;
import edu.wpi.first.math.VecBuilder;
import edu.wpi.first.math.geometry.Pose2d;
import edu.wpi.first.math.geometry.Rotation2d;
import edu.wpi.first.math.numbers.N1;
import edu.wpi.first.math.numbers.N3;
import edu.wpi.first.math.util.Units;
import edu.wpi.first.wpilibj.smartdashboard.Field2d;
import frc.robot.Constants.VisionConstants;
import frc.robot.subsystems.DriveSubsystem;
import java.util.List;
import java.util.Optional;
import org.photonvision.EstimatedRobotPose;
import org.photonvision.PhotonCamera;
import org.photonvision.PhotonPoseEstimator;
import org.photonvision.PhotonPoseEstimator.PoseStrategy;
import org.photonvision.PhotonUtils;
import org.photonvision.simulation.PhotonCameraSim;
import org.photonvision.simulation.SimCameraProperties;
import org.photonvision.simulation.VisionSystemSim;
import org.photonvision.targeting.PhotonPipelineResult;
import org.photonvision.targeting.PhotonTrackedTarget;
public class Vision {
private final PhotonCamera m_camera;
// private final PhotonCamera cameraNote;
private final PhotonPoseEstimator photonEstimator;
private double lastEstTimestamp = 0;
// Simulation
private PhotonCameraSim cameraSim;
private VisionSystemSim visionSim;
public Vision(PhotonCamera camera) {
m_camera = camera;
photonEstimator = new PhotonPoseEstimator(
kTagLayout, PoseStrategy.MULTI_TAG_PNP_ON_COPROCESSOR, m_camera, kRobotToCam);
photonEstimator.setMultiTagFallbackStrategy(PoseStrategy.LOWEST_AMBIGUITY);
// ----- Simulation
if (Robot.isSimulation()) {
// Create the vision system simulation which handles cameras and targets on the
// field.
visionSim = new VisionSystemSim("main");
// Add all the AprilTags inside the tag layout as visible targets to this
// simulated field.
visionSim.addAprilTags(kTagLayout);
// Create simulated camera properties. These can be set to mimic your actual
// camera.
var cameraProp = new SimCameraProperties();
cameraProp.setCalibration(960, 720, Rotation2d.fromDegrees(90));
cameraProp.setCalibError(0.35, 0.10);
cameraProp.setFPS(15);
cameraProp.setAvgLatencyMs(50);
cameraProp.setLatencyStdDevMs(15);
// Create a PhotonCameraSim which will update the linked PhotonCamera's values
// with visible
// targets.
cameraSim = new PhotonCameraSim(m_camera, cameraProp);
// Add the simulated camera to view the targets on this simulated field.
visionSim.addCamera(cameraSim, kRobotToCam);
cameraSim.enableDrawWireframe(true);
public PhotonPipelineResult getLatestResult() {
return m_camera.getLatestResult();
public PhotonPipelineResult getLatestCameraResult() {
* The latest estimated robot pose on the field from vision data. This may be
* empty. This should
* only be called once per loop.
* @return An {@link EstimatedRobotPose} with an estimated pose, estimate
* timestamp, and targets
* used for estimation.
public Optional<EstimatedRobotPose> getEstimatedGlobalPose() {
var visionEst = photonEstimator.update();
double latestTimestamp = m_camera.getLatestResult().getTimestampSeconds();
boolean newResult = Math.abs(latestTimestamp - lastEstTimestamp) > 1e-5;
visionEst.ifPresentOrElse(
est -> getSimDebugField()
.getObject("VisionEstimation")
.setPose(est.estimatedPose.toPose2d()),
if (newResult)
getSimDebugField().getObject("VisionEstimation").setPoses();
if (newResult)
lastEstTimestamp = latestTimestamp;
return visionEst;
* The standard deviations of the estimated pose from
* {@link #getEstimatedGlobalPose()}, for use
* with {@link edu.wpi.first.math.estimator.SwerveDrivePoseEstimator
* SwerveDrivePoseEstimator}.
* This should only be used when there are targets visible.
* @param estimatedPose The estimated pose to guess standard deviations for.
public Matrix<N3, N1> getEstimationStdDevs(Pose2d estimatedPose) {
var estStdDevs = kSingleTagStdDevs;
var targets = getLatestResult().getTargets();
int numTags = 0;
double avgDist = 0;
for (var tgt : targets) {
var tagPose = photonEstimator.getFieldTags().getTagPose(tgt.getFiducialId());
if (tagPose.isEmpty())
continue;
numTags++;
avgDist += tagPose.get().toPose2d().getTranslation().getDistance(estimatedPose.getTranslation());
if (numTags == 0)
return estStdDevs;
avgDist /= numTags;
// Decrease std devs if multiple targets are visible
if (numTags > 1)
estStdDevs = kMultiTagStdDevs;
// Increase std devs based on (average) distance
if (numTags == 1 && avgDist > 4)
estStdDevs = VecBuilder.fill(Double.MAX_VALUE, Double.MAX_VALUE, Double.MAX_VALUE);
else
estStdDevs = estStdDevs.times(1 + (avgDist * avgDist / 30));
return estStdDevs;
// ----- Simulation
public void simulationPeriodic(Pose2d robotSimPose) {
visionSim.update(robotSimPose);
/** Reset pose history of the robot in the vision system simulation. */
public void resetSimPose(Pose2d pose) {
visionSim.resetRobotPose(pose);
/** A Field2d for visualizing our robot and objects on the field. */
public Field2d getSimDebugField() {
if (!Robot.isSimulation())
return null;
return visionSim.getDebugField();
public double getChosenTargetRotation(int targetID) {
var result = getLatestCameraResult();
// Get a list of all of the targets that have been detected.
List<PhotonTrackedTarget> targets = result.getTargets();
double rotation = 0;
// For each target we have check if it matches the id you want.
for (PhotonTrackedTarget target : targets) {
if (result.hasTargets()) {
if (target.getFiducialId() == targetID) {
// Use the value of target to find our rotation using the getYaw command
return target.getYaw();
} else {
rotation = 0;
return rotation;
public double getChosenTargetRange(int targetID) {
double range = 0;
range = PhotonUtils.calculateDistanceToTargetMeters(
CAMERA_HEIGHT_METERS, // Previously declarde
TARGET_HEIGHT_METERS,
CAMERA_PITCH_RADIANS,
Units.degreesToRadians(target.getPitch()));
return range;
return 0;
public double getRange() {
var result = getLatestResult();
double range;
// First calculate range
Units.degreesToRadians(result.getBestTarget().getPitch()));
return range;
} else {
// If we have no targets, stay still.
return 0;
// When this is implemented - DO NOTHING IF RANGE IS 0
public double getYaw() {
double yaw = 0.0;
// Calculate angular turn power
// Remove -1.0 because it was inverting results.
yaw = result.getBestTarget().getYaw();
return yaw;
public double getPitch() {
double pitch = 0.0;
pitch = result.getBestTarget().getPitch();
return pitch;
Note Detection Subsystem:
// Copyright (c) FIRST and other WPILib contributors.
// Open Source Software; you can modify and/or share it under the terms of
// the WPILib BSD license file in the root directory of this project.
package frc.robot.subsystems;
import static frc.robot.Constants.VisionConstants.kCameraNameNote;
import edu.wpi.first.math.controller.PIDController;
import edu.wpi.first.wpilibj2.command.SubsystemBase;
import frc.robot.Constants;
import frc.robot.Vision;
public class NoteFinder extends SubsystemBase {
final double CAMERA_HEIGHT_METERS = Units.inchesToMeters(12);
final double TARGET_HEIGHT_METERS = Units.feetToMeters(0);
// Angle between horizontal and the camera.
final double CAMERA_PITCH_RADIANS = Units.degreesToRadians(0);
// How far from the target we want to be
final double GOAL_RANGE_METERS = Units.feetToMeters(0);
// Change this to match the name of your camera
// CHANGED CAMERA NAME TO A CONSTANT
//static PhotonCamera camera = new PhotonCamera("Microsoft_LifeCam_HD-3000");
//static PhotonCamera camera = new PhotonCamera(Constants.kCamName);
// PID constants should be tuned per robot
final double LINEAR_P = 0.1;
final double LINEAR_D = 0.0;
PIDController forwardController = new PIDController(LINEAR_P, 0, LINEAR_D);
final double ANGULAR_P = 0.05;
final double ANGULAR_D = 0.0;
PIDController turnController = new PIDController(ANGULAR_P, 0, ANGULAR_D);
DriveSubsystem m_drive;
Vision m_vision;
public double getRotation()
var result = m_vision.getLatestResult();
double rotation;
rotation = -turnController.calculate(result.getBestTarget().getYaw(), 0) * Constants.kRangeSpeedOffset;
} else {
rotation = 0;
return rotation;
// HEADER - METHOD TO FIND DISTANCE FROM TARGET
double range;
range =
// THE FOLLOWING EQUATION CAN BE USED TO CALCULATE FORWARD SPEED
// Use this range as the measurement we give to the PID controller.
// -1.0 required to ensure positive PID controller effort _increases_ range
double forwardSpeed = -DriveSubsystem.turnController.calculate(range, GOAL_RANGE_METERS);
return forwardSpeed * Constants.kRangeSpeedOffset;
} else {
return 0;
// This is a method it get distance
public double getDistance()
double range;
range =
} else {
return 0;
return range;
/** Creates a new Navigation object when used. */
public NoteFinder(Vision vision) {
m_vision = vision;
@Override
public void periodic() {
// This method will be called once per scheduler run
SmartDashboard.putNumber(“Sim-Robot (Vision) Speed”, getRange());
SmartDashboard.putNumber(“Sim-Robot (Vision) Rotation”, getRotation());
public void setDriveController(DriveSubsystem robotDrive) {
m_drive = robotDrive;
public int NearestNotePosition() {
return 1; // Placeholder for when vision is utilized in here to find a notes position
Note Detection Command:
package frc.robot.commands;
import edu.wpi.first.wpilibj2.command.Command;
import frc.robot.subsystems.Intake;
import frc.robot.subsystems.NoteFinder;
public class MoveToClosestNote extends Command {
/** Creates a new MoveToClosestNote. */
private final NoteFinder m_NoteFinder;
private final DriveSubsystem m_drive;
private final Intake m_IntakeSystem;
public MoveToClosestNote(NoteFinder finder, DriveSubsystem drive, Intake intake) {
// Use addRequirements() here to declare subsystem dependencies.
m_drive = drive;
m_NoteFinder = finder;
m_IntakeSystem = intake;
// Called when the command is initially scheduled.
@Override
public void initialize() {
// This stops the command if note finder can’t find note; Seth is forcing me to write fancy.
if(m_NoteFinder.getRotation() == 0 && m_NoteFinder.getRange() == 0) {
this.cancel();
// Called every time the scheduler runs while the command is scheduled.
@Override
public void execute() {
double rotation = m_NoteFinder.getRotation();
double speed = m_NoteFinder.getRange();
if(speed > 4)
speed = 4;
else if (speed < -4) {
speed = -4;
speed = Math.abs(speed);
speed += Constants.kDefaultNoteFinderSpeed;
if(Math.abs(rotation) > 0.05)
m_drive.drive(speed, 0, -rotation, false);
else if(speed != 0){
if(speed < 2) {
m_drive.drive(2, 0, -rotation, false);
else {
m_drive.drive(Constants.kDefaultNoteFinderSpeed, 0, 0, false);
public boolean isFinished() {
return m_IntakeSystem.NoteIsPresent();
// Called once the command ends or is interrupted.
@Override
public void end(boolean interrupted) {}
// Returns true when the command should end.
Full code:
